TPE Nova 3 (Class 68 + Mk5s) updates and withdrawal from service
DarloRich
Fenny Stratford
It normally is. Comes ECS from Longsight arriving at 15:17, and is normally sat on top of another train when I've got on it.
thanks - will change my target train for Friday travel from now on ( was surprised to see it class 68 hauled the other week)
Hugh Longworth
15 Apr 2021
Wirral
I passed Longsight this morning about 10am and saw two Class 68s with TPE sets. One of these was 68029. Can anyone tell me the other, and what the sets were? I passed again later, about 2pm. 68029 and its set was still there, but the other set had gone. There was also two more Class 68s in TPE livery visible, but not attached to any trains. Can anyone tell me the number of these?
Many thanks in advance.
Hugh
Would anyone be able to share the diagrams for this Saturday (26th March) please? :)
They will be as per post #1084, plus a Cleethorpes based training diagram (in case you're out spotting) :)
317 forever
21 Aug 2010
North West
Due to engineering works in the Stalybridge area on Saturday April 23rd, there are direct trains from Manchester Piccadilly to Scarborough at 07.26 and 15.29. There are return direct trains from Scarborough at 15.34, 20.34 and 21.34. There are similar numbers of direct trains on Sunday 24th but some of those are at different times.
I wonder how likely these are to be class 68 & Nova 3?
All except the 21.34 are booked a Nova 3. The 15.29 runs off Piccadilly every day normally anyway.
317 forever
21 Aug 2010
North West
Sunday will be all 185. Timetable still to be finalised due to Strike action
oh yes I forgot about the Sunday strikes. Admittedly I'm planning to go on Saturday 23rd a the Saturdays either side are strike days for being part of Bank Holiday weekends.
L+Y
4 Jul 2011
Are any service trains moving to Mk5s on the Cleethorpes route in May, or is everything remaining unchanged for now?
Freightmaster
7 Jul 2009
As far as I am aware, there are to be two Cleethorpes diagrams from May,
with one stabling at Longsight overnight and the other at Doncaster.
MARK
Killingworth
30 May 2018
Sheffield
Crews have been route learning since November and using some of the paths currently suspended from the timetable. 2 diagrams from May and possibly one or two more from December when the route is supposed to be extended to Liverpool. Out of service 68022 Resolution paused at Dore to confuse waiting passengers on what would have been the 11.11 Easter Monday service from Sheffield.
sjpowermac
26 May 2018
As I understand it, the original plan was two diagrams from May, four from December.
Again, as I understand it, May is looking doubtful and ‘Autumn’ seems more likely.
That said, from May there’s an out and back turn on RTT from Longsight to Cleethorpes:
5B70 0803 Longsight-Cleethorpes (1152)
5B81 1324 Cleethorpes-Longsight
Clearly in as a training run currently but might be a passenger turn at some point over the summer.
When the Scarborough services started in August 2019, there was initially one diagram per day, out and back from Longsight, so Cleethorpes might follow a similar pattern.
Sorry not to have more definite information:)
D6975
26 Nov 2009
Bristol
Looking at RTT, there are plenty of 3Bxx and 5Bxx TP paths on the Hope Valley route, but depressingly few of them are being used, and even when they are activated there are plenty of cancellations. Doesn't look too hopeful for a May start.
sjpowermac
26 May 2018
As I understand it, there are separate courses for learning the locos and learning the stock plus loco, with a break between the two.
Some of the training is classroom based, some of it involves static training and then there’s the practical handling.
So, there are always going to be quite a few paths that end up not being used.
Again, as I understand it, the training started a bit later than intended due to finalising arrangements at Doncaster Belmont for fuelling/the problems caused by Omicron/lack of rest day working agreement for drivers across TPE.
So, I’d agree totally that May is spectacularly unlikely to happen and would think the September timetable change will be the earliest the Class 68s might start.
Hope that helps:)
What is the September timetable change? Are the changes not in May and December?
Principal changes are normally made in May and December, but since Covid (and even before then) it has been more and more common for there to be large-ish changes in between. In this case the September timetable change refers to the start of a new timetable period (within the May timetable), where some operators may amend their services.
Denis103
22 Mar 2018
I have just looked for the 1529 Man Picc to Scarborough 1E41 today (27/4/22) and note it is cancelled between Manchester and York
Spartacus
25 Aug 2009
I think 1F72 may be terminating and York and forming 1E41 from there to Scarborough as that's only showing 68030 & TP11 Scarborough - York.
3 Jul 2014
Hello to all this afternoon,
Could anyone give any indication on when the class 68/mark 5a stock will run on the Redcar/Saltburn line? There has been a lot of publicity from TPE in local press and television stating that there will be a marked improvement on services with the new stock. Many thanks in advance.
Kind regards.
QS.
Fokx
18 May 2020
Kind regards.
QS.
December 2022 (full service) but will now be 2x185’s
3 Jul 2014
Hello there Fokx,
Many thanks for the clarification. I guess the Class 68’s I have recently will be connected to drive route knowledge. Many thanks again Fokx.
Kind regards.
QS.
LOL The Irony
29 Jul 2017
Chinatown, New York
Hello all,
On Saturday, me and a friend are going around Manchester using the system one travelcard and hope to get in some 68 action between Victoria and Stalybridge. Does anyone know which diagrams they'll be operating that day? Thanks in advance.
(Doesn't have to be Victoria or Stalybridge if there are some diagrams out of Piccadilly)
Freightmaster
7 Jul 2009
Hello all,
Here you go:
1E41 - https://www.realtimetrains.co.uk/service/C22361/2022-05-14/detailed
1F72 - https://www.realtimetrains.co.uk/service/C22298/2022-05-14/detailed
MARK
Sweetjesus
15 Jun 2019
I plan to travel from Manchester to Leeds and back on 27th June (Monday). Are there class 68 diagrams running on that day?
