Transport for Wales 769's
Greybeard33
18 Feb 2012
Greater Manchester
The compressor is powered from the MA set and is not tied into the Bus lines only the traction /Flex ties directly to the Bus
The fans are inverter driven from the flex side on the engine rafts and have no mechanical coupling
Ah, thanks for the correction. I believe the Motor-Alternator set is unchanged from the 319 and so will have been designed, like the traction electronics, to operate properly over the input voltage range experienced on third rail.
Am I correct in thinking that the engines need to run at a speed above idle to power all the auxiliaries that are supplied via the MA (compressor, lights etc.)?
Edit: I have since been informed by someone familiar with the units that the main (brake) compressor on the 319 and 769 is powered directly from the 750V DC bus. There is an auxiliary compressor powered from the batteries (which are charged by the MA set), but that only supplies air for raising the pantograph (not on the TfW units obviously).
Senna1210
30 May 2019
No the units are quite capable at idle to power everthing they have on them But the heaters do lack a bit of oooph untill the Bus line comes up
AM9
13 May 2014
St Albans
Does that mean that the bus voltage is low when idling, or is the heater load partly shed as a low priority?
DieselFan
11 Nov 2020
Caerphilly
Being local to the Rhymney line, looking forward to seeing the 769's in service...I think the last time I saw these units in action was when they were originally 319's and at the time I was living near the MML when they started running, late 1980's. They seemed state-of-the-art back then! I do think they'll be quite an upgrade to Sprinters/Pacers that we're used to here....
PHILIPE
14 Nov 2011
Caerphilly
TFW seem to be going hard at training as runs tonight on a Sunday evening after Engineering Work finished and line re-opened
craigybagel
25 Oct 2012
With the new second diagram Cardiff based crews are now working 769s. If they're training the entire Valleys depot at Cardiff that's going to take a lot of training runs.....
PHILIPE
14 Nov 2011
Caerphilly
I was wondering if Cardiff crews were training on 769s especially as the new diagram starts at Cardiff first thing in the morning.
craigybagel
25 Oct 2012
I had had exactly the same thought - which is why I checked genius the first day it ran. It makes sense if they want to get the most use of these sets.
Buzz68
4 Sep 2017
Caerphilly, South Wales
Yes Cardiff crews are undertaking a week of intensive training to pass out on them
Not mileage accumulation for these two as they are already running in passenger service. Testing etc run as 5Fxx and trainers as 5Zxx
I thought I could only see 1 crew member which made me think mileage runs.
158srule
5 Apr 2019
769008 was just a trial run post repair and 769452 was a transit move to / from Canton for fuelling. No training or running planned on Sundays.
158srule
5 Apr 2019
It always broke down before anybody was able to get a photo, that's why :lol:
99% of Northern 769 sightings have been in depots!
002 was a good unit until a mod was fitted which highlighted a problem under the train. It should be back out next week.
PHILIPE
14 Nov 2011
Caerphilly
769452 on a training run (5Z75) a complete failure at Brithdir and the fitter (travelling I presume) unable to resurrect it. 1Z99 (the Thunderbird 37) being fired up at Rhymney to rescue. I've lost track which 37 is in situ at the moment.
66050
29 Jul 2020
Caerphilly
418 I believe mate. Will she bring 452 down to Canton or stable her at Rhymney?
PHILIPE
14 Nov 2011
Caerphilly
No idea. The priority is to clear the Single Line but I presume it will draw her back to Rhymney as she will be that end on the single line.
Bikeman78
26 Apr 2018
Going back to Rhymney as it’s Mac speed 5mph.
Daft question. When 317s and 321s are been towed for scrap, the loco controls the brakes on the units. Why isn't this possible when a 37 attaches to a 769? The couplings are the same, or very similar to 317/321 etc.
158srule
5 Apr 2019
They are either towed using translator vehicles with tightlock couplings, by locos specifically fitted with tightlock couplings or they have an extended brake pipe fitted giving through brake control. None of the locos available to TfW have these so an adaptor coupler needs to be used which doesn’t give through brake control
Bikeman78
26 Apr 2018
Forgive me for labouring the point but doesn't a similar adaptor exist to the one shown in this video of a 37 rescuing a 755 to attach to 769s? It looks like it could be fitted to any loco fairly quickly.
