TheGrandWazoo
As explained....Do we know why there is no requirement for a T1C Northbound service from Cardiff up the West side of Wales when there are 5 T4 Northbound services per day between Cardiff and Newtown. None is a pretty small number compared to five. It is definitely an advantage to have five fingers instead of none.
The T1C only exists because of the clamour for a replacement for the 701 which was operated by Lewis of Llanrhystud and before that, Coach Travel Wales and Bryans Coaches. It really is no more than that. The 701 ran once a day, north to south, once a day (despite an attempt at one point to increase it to two) and so the T1C continues to do so.
Depends on how stringently you want to look at this.Not only that - but they actively decided not to take the Trawscymru strategy that way, which is and was nuts.
In terms of physical connections, then they do extend services to rail stations in places like Haverfordwest and Hereford and Carmarthen. And to pick out Carmarthen, then the buses arrive some 10-15 mins before the departures to Cardiff, for instance. However, through ticketing isn't available (other than PlusBus) and when you try to book from say Aberystwyth to Cardiff, it will default to a purely rail journey on TfW website so sending you via Shrewsbury!
As @Rhydgaled points out, there will be inevitably some limited duplication with rail. I don't think anyone would seriously suggest that the service from Dolgellau to Aberystwyth should be truncated at Machynlleth just because it the rail line also follows the A487 for a major part of the route.
