Trivia: Semi exclaves - Gaps in a TOC’s coverage where the quickest route is via another TOC
PTR 444
22 Aug 2019
Wimborne
Following on from the enclaves/ exclaves thread, I was wondering how many semi-exclaves there are on the national network. By that I mean significant gaps in the coverage of a TOC where to get between two stations only using that TOC’s services would involve a very long detour, while at the same time, there are other TOCs that provide a much faster service between the two.
For instance, there is a gap in Northern coverage between Darlington and York. If you were to travel between those stations entirely on Northern trains, you would have to go the long way round via Carlisle, and you’d be silly to do so unless travelling for leisure purposes. Most people would just take a direct train between the two stations on a LNER, XC or TPE train.
Are there any similar “noticeable” gaps in TOCs coverage within the UK?
Huntergreed
Events Co-ordinator
16 Jan 2016
Dumfries
Preston - Carlisle: Northern only would be 4+ hours on a noisy, bumpy 156 via Whitehaven, Barrow, Carnforth and Lancaster, with no coverage from Lancaster - Penrith by Northern (but they do serve Oxenholme)
Would be just over 1 hour on a 390
py_megapixel
5 Nov 2018
Northern England
From Cheltenham, you can travel in pretty much any direction using CrossCountry trains. But if you want to go to Reading on CrossCountry it's several hours via Birmingham and Oxford, which makes it far more practical to use GWR.
tbtc
16 Dec 2008
Reston City Centre
I know GC are an OAO rather than TOC, but some people could run the thirty mile distance from Doncaster to York faster than taking GC trains (via KX)
At least Doncaster - York is *only* three hours on TPE (via Manchester)
PTR 444
22 Aug 2019
Wimborne
And only 20 minutes on LNER!
CBlue
30 Mar 2020
East Angular
Greater Anglia have a gap between Cambridge/Ely and Peterborough. If you were to use GA services exclusively you'd have to travel via Bury St Edmunds rather than the direct XC and EMR services
tbtc
16 Dec 2008
Reston City Centre
I certainly can't run that fast!
I suppose Northern from Derby to Stoke must be worth a shout (via Sheffield and Manchester, rather than EMR via Uttoxeter) and GWR from Gatwick to Brighton (via Reading and Salisbury)
mlambeuk
19 Feb 2013
York
York to Scarborough with Northern is Nearly 3 hours changing at Hull (although Northern were due to start a York to Scarborough direct service). Whereas only 45 minutes by TPE .
Ianno87
3 May 2015
Southeastern between Ashford and Hastings - need to travel via Tonbridge.
No, there are direct services:
Stansted-Cambridge-Ely-Norwich and
Ipswich-Bury-Ely-Peterborough
xotGD
4 Feb 2017
Cross Country from Glasgow to Manchester is a bit of a roundabout route. Via Brum.
CBlue
30 Mar 2020
East Angular
Strange. Fairly sure the timetable I looked at for Ipswich to Peterborough services didn't include a call at Ely.... still, they don't offer a through service unlike the other operators :)
xotGD
4 Feb 2017
Caledonian Sleeper from Inverness to Aberdeen via Preston.
mrcheek
11 Sep 2007
Weymouth to Southampton is a nice straight journey by SWR.
a bit of a detour if you choose to go via GWR
nr758123
3 Jun 2014
West Yorkshire
I’ve done Brighouse to Sunderland via the Settle & Carlisle, a journey inspired by my determination to get my money’s worth out of a delay voucher from Northern.
61653 HTAFC
18 Dec 2012
Another planet...
If I'm understanding the topic correctly, Huddersfield to Leeds on Northern would qualify. Direct service only on Sunday (pre-Covid) via Bradford. All other times require a change at one of Bradford, Brighouse, Mirfield, Wakefield Kirkgate or Castleford. Faster direct journeys via Dewsbury are all TPE.
PeterC
29 Sep 2014
London Overground have a totally detached service between Romford and Upminster.
DB
Guest
18 Nov 2009
The stopper on that route was Northern until a few years ago. Never did see the logic in moving it to TPE, given that most of their services are limited-stop.
ABB125
23 Jul 2016
University of Birmingham
Penzance to Bournemouth on CrossCountry (via Birmingham). Similarly Manchester to Edinburgh, Stansted to Reading.
Hereford to Shrewsbury on West Midlands, and Hereford to Crewe (and Shrewsbury to Crewe!).
Bending the rules slightly, Fort William to Inverness on ScotRail. Much quicker to get the bus!
NoMorePacers
18 Feb 2016
Humberside
On Northern's network, definitely York to Darlington. Half an hour on the direct services, using Northern it's about 6 hours (going via Leeds, Carlisle, Newcastle and Hartlepool).
NSE
3 Mar 2010
I've always thought it, not weird, but just interesting, that Intercity TOC's that run in 'straight lines' from London frequently won't connect between their key destinations. For example, Avanti have Birmingham and Liverpool has key cities, but you can't go direct between (I think?). Birmingham/Manchester is another that can only be done during the peaks. On the ECML, Leeds to Edinburgh/Newcastle for example, is it just the one Aberdeen that they have? Considering they are often they 'flagship' TOC so to speak, I always found that, yeah, interesting haha
Parallel
9 Dec 2013
Brighton to Gatwick Airport on GWR. Via Southampton, Westbury, Newbury and Reading.
Obviously much quicker to go with GTR.
Exeter to Bristol with SWR via Salisbury. Usually much quicker with either GWR or XC direct.
xotGD
4 Feb 2017
Hull to Scarborough on TPE via Leeds.
Back to the Caledonian Sleeper, any two stations between Edinburgh and Aberdeen requires a trip to Preston and back. Do they call at Watford Junction? If so then to get from there to Euston you'd have to go via Edinburgh or Glasgow.
London Trains
9 Oct 2017
Tonbridge to Ashford on Southern (would have to travel Tonbridge - Redhill - Gatwick - Eastbourne - Ashford)
_toommm_
8 Jul 2017
Stalyvegas to Manchester Piccadilly with Northern, now that they don't run to/from Huddersfield in the morning and evening peaks. Fastest is with TPE direct, with Northern you have to change at Salford Crescent.
24 Sep 2017
St Pancras to London Bridge via Southeastern.
Upwey to Yeovil Pen Mill via SWR.
Ely to Peterborough via GTR
Doncaster to Retford via Northern.
Wokingham to Ash via SWR
Guildford to Reigate via GTR
Southampton to Basingstoke via GWR
You could even argue Euston to Liverpool via West Midland Trains, but not really in the spirit of the thread.
Also until recently Newcastle to Edinburgh via TPE
Halish Railway
26 Apr 2017
West Yorkshire / Birmingham
Sorry if these have already been mentioned:
Inverness to Aberdeen only on LNER via Haymarket.
Scarborough to Whitby only with Northern - service to Hull, then Leeds, then Carlisle and then if possible, a direct service to Whitby. If that’s not possible then a change at Middlesbrough.
