Not just a bit excessive but a confounded nuisance. Walschaerts is a complex gear (evidently) which requires a screw reverser. Shunting is just forwards-back-forwards-back. With a pole reverser you just whack the lever forwards and backwards, you only ever use full gear to start. Screw reverse means you have to wind and wind and wind and wind to get from forward to backwards - and 20 seconds later all that winding again. And for the whole shift ...
Apparently the 94xx, although simpler Stephenson gear, had screw reverse as well - for a designated heavy shunter
Same with superheaters. A real nuisance in shunting, there were some accidents. The regulator is in the dome. If you shut it on a non-super loco, the steam supply direct to the cylinders stops pretty instantly. On a superheated loco, after the regulator, you have high pressure steam in all the length of the superheater, often wrapped fore and aft the length of the boiler four times to get rid of first. On the main line it doesn't really matter. It does when shunting.
