What makes a train look British?
XAM2175
8 Jun 2016
Add some buffers and I think you're onto something. Perhaps it's the big windows that do it?
They did have buffers to begin with - you can see them in the first photo!
As it is, if you take the body off the 422 class have a lot more in common with the CIÉ 071 class than anything British.
29 Aug 2010
No silly windows all over the place with about 300 different floor heights.
Irascible
21 Apr 2020
Dyfneint
It does have a couple of features not generally seen on UK LHCS, the ends being painted a colour other than black and hopper windows (common on multiple units of course but never fitted to any LHCS here), also a very different style of gangway connection.
Yeah, I mentioned the gangways - we did have a fair amount of coaching stock with coloured ends though & hopper windows are a feature of DMUs. I think it does show that the real difference is the height.
It may not have been the case many years ago, but isn't the Irish loading gauge fairly similar to GB nowadays? It's probably safe to assume that had either Irish or Brunel gauge become the GB standard, the restricted loading gauge would have mostly remained.
Can't find the loading gauge envelope at the moment, but I believe it's wider & not particularily taller, which would help in a few ways if not really helping with our current problem of tall containers. If the gauge commission had gone for Brunel's then I can't see a Stephenson-sized loading gauge persisting ( or what would have been the point? ), we'd have just had to suck it up & redo all our bridges & tunnels - which would be a hard stop to the excesses of the time, possibly us ending up with the network we really needed & a rather different & interesting path for the rest of the world - would everywhere have ended up 5'+ I wonder.
In the Big Boy's case, this was somewhat deliberate, as they were designed/built to haul massive loads and be as reliable/easy to maintain as possible as you say. I hold the opposite view to yourself in that I can find beauty in functionality, but hey: each to their own.
They weren't all just functional ( and I think some european designs were worse ) even ignoring the streamlined ones. Here's one I was always rather liked -
which doesn't really look that much different to the export models British builders were producing. Domestically we just tended to hide pipework a bit more, I think.
Doomotron
25 Jun 2018
Kent
I see it now. It does look quite British with them! Although I'd say they look more like a 50 than a 47.
AY1975
14 Dec 2016
And the UK doesn't mark Standard class, that being the default. Just the presence of a big 2 by a door looks European.
Yes, and at least in the BR era and in the early days of privatisation BR (and its successors) didn't usually mark smoking accommodation. In the pre-nationalisation era both smoking and non-smoking accommodation was marked, though.
SussexLad
7 Jan 2020
For me it's a combination of things:
- rarely having level boarding at stations
- badly designed toilets that always smell
- a bumpy ride
32475
2 Nov 2019
Sandwich
Such an interesting topic. I probably first pondered this subject in the 1970’s when I first travelled by train in France a bit. Getting the boat train from Dieppe to Rouen hauled by a BB67000 or something similar, I thought then how similar they were to a class 47 and yet how subtly different. Although the two are sort of similar in proportion, they have a split windscreen, both predominantly blue and with central vents over the cab fronts, the SNCF beast definitely had a foreign air about it. It was that bit bulkier to look at, it had angled side vent panels rather like a contemporary Renault or Citroen car might and the side panelling came down to not far above track level. Typically brash, Gallic and less reserved in design terms. Look at these two images c/o Wikipedia and make your own mind up. Having said that, the Class 52s were radical and the Warships were reminiscent of German and Danish loco design. As for the HS4000 Kestrel built by Brush, now that really was a European looking locomotive not least because they were looking for foreign export orders.
norbitonflyer
24 Mar 2020
SW London
As was the DP1 Deltic prototype. My model looks quite at home pulling Triang "Transcontinental" rolling stock.
py_megapixel
5 Nov 2018
Northern England
I understand that the reason for this is to allow the doors to be at a height lower than the floor above the bogies needs to be, which makes level boarding (with the aid of gap fillers) easier to accomplish. It's actually an excellent idea and it's frankly embarrassing that it's not been adopted in this country by more than just Greater Anglia.
You can make it not look rubbish by way of a dark window band. That enhances pretty much every livery anyway.
Irascible
21 Apr 2020
Dyfneint
The Warships ( not the first ones ) were a fairly literal copy of the German V200s, just squashed into our loading gauge. BR licensed the whole design iirc. That would be a good thing to compare in detail.
LOL The Irony
29 Jul 2017
Chinatown, New York
I can see a passing resemblance but not much else. I think you'd find most noseless locomotives all look broadly similar as they are just a cuboid with some wheels underneath.
They do look European, but the design of the Kestrel was an in thing at the time. The design language kind of harks back to streamlining, which had kind of made a return thanks to the 0 Series Shinkansen. I do however, see a little bit of Flying Hamburger in there. The HS4000 is still the most beautiful looking train to ever ride these rails.
Strathclyder
12 Jun 2013
Clydebank
Oh, indeed (that is one handsome New York Central machine BTW). It's just that the almost purely functional Amercian ones - most notably UP Challengers/Big Boys & SP Cab-Fowards - tend to stick in the memory and overwhelm all the others.
Doomotron
25 Jun 2018
Kent
The USA could make some beautiful locomotives when they tried, like the PRR T1 and S1, and the New York Central Hudsons. But of course none of them looked British in any way!
driverd
29 Mar 2021
Can't agree more with the sentiment though! European trains just look untidy with the messy window layout, and the saloons look hideously badly presented with seats at all different heights. It's my main aesthetic complaint with the Stadler stuff. Functionally 10/10, but gosh they look hideous both inside and out.
52290
23 Oct 2015
When I reached Cordoba in 1967 I was surprised that the GWR had got there first.
AY1975
14 Dec 2016
The level boarding issue is at least being addressed with Greater Anglia's new Class 745 and 755 FLIRTs. Is level boarding found on trains in any other countries?
Smelly toilets also used to be common in some other European countries: the former East Germany for example.
Talking of toilets, in Britain older side corridor coaches usually had the toilet door at the end of the corridor (except Mark 1 Corridor Seconds which had two toilets opposite each other at one end of the coach just like Tourist Open Seconds). Early Mark 2 and Mark 2A Corridor and Brake Corridor Firsts also had the toilet door at the end of the corridor but Mark 2B, 2C and 2D FKs and BFKs had it in the vestibule (which AFAIK has always been the norm in mainland Europe). Not sure why it was decided to change to having it in the vestibule with the Mark 2B FK and BFK, or why they didn't do it like that on older coaches. I can't think of any particular advantage or disadvantage of either layout.
Mind you, on some of the German ICE sets that have compartments at the ends of the coaches the toilet door is in the corridor just like on Mark 1s and early Mark 2s. I also once travelled in an Austrian couchette car with a three-quarter width toilet compartment with the door in the corridor.
Some Continental couchette cars, and even some older ordinary seated side corridor coaches in mainland Europe, had a separate washroom with just a washbasin at the end of the corridor and a toilet off the vestibule. I expect that would have caught some British tourists out who were used to Mark 1s and who tried the separate washroom expecting to find a toilet!
D6130
12 Jan 2021
West Yorkshire/Tuscany
RFI - the Italian infrastructure provider - is currently about half-way through a massive programme of raising platforms at busier stations to give level access to the new generation of disabled accessible units and easier access to older stock with 3/4 step access.
AlexNL
19 Dec 2014
Absolutely. Here in the Netherlands, ProRail (infrastructure manager) are currently executing a multi-year program to made sure all platforms are at 76cm above top of rail. All new rolling stock which has been ordered in the past 15 years is also being specced for 76cm above TOR.
With the withdrawal of the older SGMm trains next month, this will mark a milestone for NS: all commuter/regional rolling stock will provide level boarding. Intercity stock (which is also used on some routes where a regional train on its own would not be economically viable) does not, but with the arrival of the Intercity Next Generation (ICNG, Alstom Coradia Stream) the first steps are taken towards level boarding on intercity services.
Inversnecky
1 Jan 2021
Refamiliarising myself with the fleet after a few decades absence, I find a lot of the newer multiple units rather unusual looking. The pointy nose of the faster trains of course is a result of designing for lower wind resistance, and will follow from ‘convergent evolution’ across the world.
liamf656
2 Aug 2020
Derby
The three main things for me are yellow fronts, gangway connections and the loading gauge. I work on trains to St Pancras and the Meridians/Javelins are dwarfed by the Eurostar trains beside them!
Strathclyder
12 Jun 2013
Clydebank
Don't forget the PRR GG1 electric locos and - this one is subject to debate I'll concede - the Baldwin Sharknose diesels, specifically the RF-16s. The early EMC/EMD bulldogs/streamliner diesels were rather striking to look at too.
JRT
11 Nov 2020
Bradford
A few years ago I caught a Trenord DMU from Molteno (Lecco).
So this was a bit like the first generation DMUs I remember from 1960 that ran from (Bradford Exchange) via Laisterdyke to Leeds Central.
Exterior was the local livery.
Interior was like going back in time as it had the circular light fittings with a filament lamp in the centre of a disc.
