Yes, true. You only have to look at DB IC/non-HS ICE for what XC could be (Germany's demand is very distributed and not single-city-centric like our other IC operations), and it doesn't even come close to muster.
They have good services between all their regional centres???
Can't comprehend.
The problem with Castlefield is less the individual services and more the fact that a problem on it (which there is most days in some form) knackers the punctuality of services most of the way across the North because so much goes through it.
I wouldn't say that most of the individual services that pass through it are all that grim.
Some are okay, the maligned EMR services and the stuff up to Southport can be pretty rubbish though.
None of this compares to the Central line at rush hour, where the trains are so physically full that you can't actually board the first 10 trains.
I don't get the moaning about castlefield, so you had to stand and were delayed for a few minutes? So what that's pretty normal for rush hour.
Plus it's nowhere as busy as London Bridge or East Croydon, to name a few.
Yeah, the trains on Castlefield are so physically full you can't fit on them (pre-covid), this is very standard in Manchester for rush hour, difference is, trains to where people are going are not a few minutes apart but often as infrequent as once per hour.
The fact it isn't as busy as the central line or London Bridge, yet people are left behind on platforms and delays are a given shows how shocking it really is. Remember, Oxford Road has the most delays of any mainline station in the county by a decent margin. Over 70% of services are delayed/cancelled.
Obviously London isn't perfect and I think the level of investment is justified. Crossrail IS needed to increase capacity on the tube. However, the rest of the country ALSO needs to see investment. The projects in London, especially junction realignments, etc, do really improve things, so doing that to the rest of the networks pinch points would help.
For a long, slow service you need lots of capacity, high comfort and good on-board facilities like catering as well as space to use laptops etc.
XC has none of those lol.
I guess it does have the advantage of doing 125mph sometimes.
Under normal circumstances it's safe to assume that everything between birmingham and the South Coast on XC is crammed (Not just that though)
In my experience, the Northern section is worse, but usually I head towards Bristol after Brum.
Crewe to Derby is pretty grim, it's one of the few lines that has a worse service compared to 20 years ago.
I don't know why but many of the local services around Doncaster and Teesside seem grim.
Oh yeah! How did I miss it. A rammed full class 153, through the noisest tunnel in the world near Stoke.
Delayed by a few minutes pre COVID quite often turned into delayed by 20 minutes as train after train runs in front of you, losing your path to 3000 tonnes of Derbyshire at Chinley, waiting for it to grind through the Dore Curve or crew change at Sheffield and then being cancelled at Nottingham.
Been there, done that, bought the t-shirt far too many times.
I totally feel your pain, as I have been there too. I don't know why a relatively short distance between Manchester and Derby/Nottingham turns into some ridiculous saga.
