Why is Southern's Redhill to Tonbridge service crewed by Southeastern?
KT550
23 Dec 2020
I travelled this route today and noticed that both driver and guard were Southeastern?
I could understand if the first departure from TON becomes the first departure from RDH but this appears not to be the case.
Has this always been the case since electrification?
Thanks
Doomotron
25 Jun 2018
Kent
I expect (but I'm not sure; I'm sure someone with better information will post here) that it has something to do with when the line changed from being operated fully by Southeastern (or it may well have been Connex!) to Southern.
Flange Squeal
17 Jul 2012
I can't answer why Southeastern are crewing Southern services today, but until December(?) 2008 the intermediate stations were in fact managed by the South Eastern franchise, with Connex (later Southeastern) running Class 508s between Tunbridge Wells and London Bridge along the route. I think the South Central franchise had begun operating some services of their own in the final years leading up to the transfer of stations and services to that franchise though, alongside Southeastern's own services.
Sounds like Redhill is a bit of a mecca for crews operating other TOCs' services though, with some GWR services to Reading worked by Southern drivers.
Edit: @Doomotron has touched on the same while I was typing!
HamworthyGoods
15 Jan 2019
Thanks
It’s so South Eastern crews at Tonbridge retain route knowledge over this route for diversion.
Whilst hiring in crews is less common than it used to be if the arrangement suits all parties there’s no particular reason to change it.
Aictos
28 Apr 2009
That's a good reason but I don't understand why it was transferred to Southern in the first place, surely it should have been left with South Eastern in the first place seeing as they operate over the route for retaining route knowledge anyway?
D6975
26 Nov 2009
Bristol
Another separate point about Tonbridge is that the ticket barriers won't accept Southern Daysave tickets, despite it being valid.
Because the DfT said so.
The examples have decreased over the years, but there still quite a few services that are 'operated' by one TOC but crewed (sometimes or always) by another.
In most cases it's an artefact of privatisation causing route to be split up rather arbitrarily between TOCs, even when operationally it would make a lot more sense (and would be cheaper) to keep things integrated.
At the point the route was transferred to Southern, Southeastern then ceased to run services on the section between London Bridge and Redhill, and some Tonbridge services worked through to both Victoria and London Bridge. The transfer of London Bridge services to Thameslink consequently led to Redhill to Tonbridge being operated as a standalone shuttle.
The point of not leaving it with Southeastern therefore was to enable all services on the London to Redhill route to be operated by Southern.
Starmill
18 May 2012
Bolton
Do Southern drivers sometimes work to Tonbridge? I would guess that the answer is yes? And if they do, do they do so without a Conductor, unlike the Southeastern driers?
warwickshire
6 Feb 2020
leamingtonspa
Yes if its southeastern driver and guard.
It's the usual method ie driver open.
Guard closes the doors.
If its southern driver and southern onboard supervisor where provided
Ie sometimes doo as well.
However southeastern have no agreement for obs in any part.
Hence why southeast guards retain there usual method off working.
KT550
23 Dec 2020
Thanks. That makes sense.
So, how do Southeastern crews retain their route knowledge from Redhill north to London for diversion days?
Horizon22
Jobs & Careers
8 Sep 2019
There's a daily set of empties to London Bridge and back
This is a relatively new development - for some time there wasn't and route knowledge was stating to wane.
This can indeed get a little complicated as one trip might be an OBS, the return could be an SE guard.
Wait, SN drivers can operate GWR stock?
Yes, it avoids GWR having to have a driver depot at Redhill, just as using Southeastern staff avoids Southern having to have a traincrew depot at Tonbridge. (GWR have a small compliment of guards at Redhill.)
paul1609
28 Jan 2006
Wittersham Kent
When the Uckfield line was modernised with Class 171s and all day through trains to London Bridge in the early 2000s there were major losses of passengers from all the Kent stations on the Redhill to Tonbridge Line. Today the lines somewhat of a backwater with school kids the major traffic which don't need a through service to London.
Nicholas Lewis
9 Aug 2019
These are historical arrangements as Redhill has always had a link for North Downs lines as did Tonbridge depot.
As an aside Tonbridge drivers and guards also learnt into Victoria when it was a Tonbridge to Victoria service for of a couple of years before it was abandoned.
Taunton
1 Aug 2013
Very historical. The line from Tonbridge to Redhill and on to Reading was originally an outlier of the South Eastern Railway from Kent, worked down the jointly owned Brighton line from London Bridge to Redhill, then east and west. This service pattern persisted to at least the end of steam in the 1960s, and also through trains from one branch to the other, reversing at Redhill. When Western Region dmus took over the service in the 1970s-80s Tonbridge crews handled them, and as they also signed Ashford to Hastings such units very occasionally turned up on that line as well.
Roast Veg
28 Oct 2016
As touched upon, this was under threat since time ago. Diversions for Tonbridge to London Bridge services via East Croydon were going to become impossible, despite being quite common during major works. Pleased to hear it has not lapsed.
11 Jan 2015
And even more historically the line from Redhill to Tonbridge and on to Dover was the South Eastern Main Line as the cut-off through Orpington was only opened in 1867.
Sm5
21 Oct 2016
Why are they not run in passenger service (possibly even using Southern units)? Also, what are the headcodes?
5Y77 1122 Tonbridge -London Bridge via Redhill
5Y80 1437 London Bridge - Tonbridge via Redhill
runs daily M-F as a scheduled ECS
theres also paths for
1237 London Bridge to Redhill sdgs 5Y78
1349 Redhill sdgs to London Bridge 5Y79
1237 London Bridge to Tonbridge 5G81
1323 Tonbridge to London Bridge 5G82
5Y77/80 runs like clockwork every weekday.
The 5Y78/9 Redhill runs more often than 5G81/2.
ive only ever seen SE Blue Electrostars on it.
Surreytraveller
21 Oct 2009
There won't be any Southern units available, as they're in use on the Redhill to Tonbridge services.
If these trains ran in passenger service, there would be an obligation to run them, and penalties for cancelling them.
Southeastern would also be entitled to a revenue share if they ran in service
CarrotPie
18 Mar 2021
̶F̶i̶n̶l̶a̶n̶d̶ Northern Sweden
Thanks both
Please delete ^
New message:
Thanks, that explains things.
None of these headcodes bring up anything in RTT... It is half 10 on Tuesday in the UK right now, right?
5G81 and 5G82 can't both run (with the same unit and crew) as the schedules pass between Penshurst and Leigh - presumably they are there in case the unit is not available for 5Y77 or needed before 5Y80 is due back at Tonbridge.
Yes, there are only two LTP crew diagrams on these circuits and they swap over on 5Y78 at Redhill around 13:00.
As you say, I imagine several of these paths are just in the system to give flexibility on the day.
Taunton
1 Aug 2013
One wonders why the crew cannot just drive one of the Southern regular service units, or if that's not possible either, just ride along in the cab.
Fincra5
6 Jun 2009
Alas, which Southern Services from London Bridge via Redhill, are you thinking off? There only a Victoria to Reigate... Thameslink do, from London Bridge (High Level mostly) but then that would be a "Pass in Cab" situation.
