Why's my train late information
Pete_uk
28 Jan 2017
Stroud, Glos
I'm watching a few late trains on the GWML including 1G11 which seems to make up then loose time. I know some people have access to information systems which gives detailed information on what's going on. Is this information available anywhere for us not in the employ of the railways?
Thanks in advance!
Max
8 Jun 2005
Cambridge
There are a number of sites out there which provide detailed train running information. www.realtimetrains.co.uk provides the times that trains pass various timing points in addition to station call. www.opentraintimes.com has an excellent map function which shows the locations of trains in real time on track diagrams.
These are two of my favourites, but I'm sure there are others out there!
DarloRich
Fenny Stratford
if you mean detailed reasoning behind the cause of a delay: No it isnt
If you mean can I work out where a train is and how late it is then the suggested sites above are a good start.
Y Ddraig Coch
1 Nov 2013
Thanks in advance!
If you mean 1G11 London Paddington to Cheltenham Spa it has 13 minutes dwell time at Gloucester where it reverses. It managed to arrive and reverse in just 7 minutes meaning it was only +2 leaving Gloucester.
That's where the time was made up mainly.
trainophile
28 Oct 2010
Wherever I lay my hat
Some stations seem to routinely finish their "delayed" announcements with a reason of sorts. I wish they all did, it's really annoying to keep hearing "we apologise for any inconvenience this may cause". We would be a lot more forgiving if we knew what was going on.
221129
21 Mar 2011
Sunny Scotland
That is only if the info is put in or known.
Bantamzen
4 Dec 2013
Baildon, West Yorkshire
I tend to use these two sites to check the possible situation when delays start to happen. Between them it helps paint a picture, for example if my first train of the day is delayed, RTT helps give me an idea if I'll make my first connection, or if I need to change plans (I have connect at two stations for my onward travel on my commute). And if I'm on a train that grinds to an unexpected halt, OpenTrainTimes can be used to see if there are other services around of us that might indicate how long a delay might be. As others have said they don't necessarily tell you why a problem has arisen, but you can gleam some idea of what kind of delay you might expect.
tom73
24 Apr 2018
Going off topic very slightly, is there a website which shows the entire activity of a unit from it leaves the depot in the morning until it returns at night. For example, first weekday train to Leeds from King's Cross. What does it do before it arrives in the platform to take on its first passengers. How long before scheduled departure does it arrive in the platform?
matt
30 Jun 2005
Rugby
None that are available to the public.
