johnnychips
I have a smartphone supplied by a network with 4G. I have very often noticed that on the trains I use a lot (Northern, TPE, XC) that when the train tries to connect me to the wi-fi, and indeed the wi-if bars/crescents replace the 4G symbol, I get a message saying that ‘wi-fi is not available’ on the sites I attempt to connect to. I assume it tries to connect me as I have registered and used these companies’ service in the past. The same thing happens with First buses.
So I switch wi-fi off and revert to 4G, which reconnects immediately.
To come to the point, is wi-fi worth bothering about, seeing as it is so inconsistent and 4G so good? This thread was also inspired by a quote from @Watershed , though I’m not sure which company or train he was referring to.
Indeed. I'm surprised they ever introduced WiFi if it was as expensive as they're making out.
Instead I rather suspect the availability of WiFi isn't a dealbreaker for most passengers, and so it's been removed as part of a cost-cutting review.
But again, Covid really is being used as an excuse here.
