YorksLad12
Arthington: yes, there was a curve. Did regular, timetabled passenger services run over it? They would have missed out Arthington if so (unless they reversed). I'll use timetableworld.com to see if there were , for example, any Skipton-Harrogate services.Arthington needs a N to W curve adding.
Shipley station is shown on the 6in map of 1852 just North of Valley Road bridge, some way south of the present station; also, is there any way of showing that the present triangular arrangement of platforms only dates from 1979?
Shipley: Wikipedia says
There was a goods yard at that point, although that might have been on the site of the former station. More to investigate here!The Ordnance Survey map of Shipley in 1852 (surveyed between 1847 and 1850) shows the station some 500 m south of the present one, where Valley Road crosses the line to Bradford. However, an article in the Bradford and Wakefield Observer in February 1849 describes the station in its present position. It is not clear if it was moved in its first few years or there is an error on the map.
And: no, not really as the station is in that state now and open. If one set of platforms was removed it would be easy to show that they had been there but redevelopment of a station to add more can't be done (see Leeds).
