More than one change from Manchester?
Ivo
8 Jan 2010
Bath (or Southend)
Completing the set of the largest and most powerful cities in England, how many places require more than one change from Manchester? It should be noted that a large number of those that are inaccessible from Birmingham are covered by the EMT Liverpool to Norwich service...
I'll start things off with Stourbridge Town. An easy way to kick things off.
Welshman
11 Mar 2010
Anywhere on the Far North or Kyle branches, and in the winter months, anywhere on the Falmouth, Newquay, or St Ives branches is all I can come up with.
I was surprised at what a comprehensive rail service Manchester has.
Robinson
1 Aug 2010
Helensburgh
Anywhere in Southeastern-land that isn't directly accessible from Euston on the Underground, if we include the changes onto and off the tube separately. Ditto the Southern network apart from the Coastway West (which only requires one change at Southampton Central).
150222
9 Jul 2011
oh I do apologise - I noticed a similar thread with London and thought it was the same :P
Cardiff Bay as I think you have to go to Cardiff central, then to Cardiff queen street and then to Cardiff bay.
Also Bromley North, Sheerness-on-Sea, Bidston, Southend !
Change at Wrexham General or Liverpool Lime St.
D841 Roebuck
16 Mar 2012
Rochdale
Streethouse, Featherstone, Pontecarlo Tanshelf?
No direct service AFAIK to Wakefield Kirkgate from Manchester...
dzug2
5 Feb 2011
You can get to rather more of Southern than that. Reigate, Redhill or Gatwick with one change at Reading. Not on Southern trains admittedly. And 'Coastway West' will actually take you to Victoria from Southampton as well as Brighton, although rather a roundabout route
12CSVT
18 Aug 2010
Unless anybody know different - Barnhill, Alexandra Parade, Duke Street, Monks Risborough, Little Kimble, St. Margarets, Ware, Hertford East, all the East London line stations
VTPreston_Tez
26 Jan 2012
Preston
Upminster? (Change at Euston and Embankment)
And anything on the District Line as a result, well any line not passing through Euston!
clagmonster
8 Jun 2005
How about Wrexham Central? Would require a change at Wrexham General and either Shrewsbury or Chester. Same for the other stations on the borderlands line apart from Bidston, which would just require a change at Liverpool Lime Street.
Also Walton-Aughton Park inclusive. Would require changes at Ormskirk and Preston or Moorfields and Liverpool Lime Street.
Robinson
1 Aug 2010
Helensburgh
Needham Market and all Greater Anglia stations south of Ipswich that the Norwich-London trains don't call at.
Track Basher
27 Nov 2010
Highlands of Scotland
How about changing at Hunts Cross or Liverpool South Parkway.
gnolife
4 Nov 2010
Johnstone
Merseyrail from Hunts Cross all go to Southport, therefore a change at Sandhills is also necessary
I'm going to suggest Hartlebury (that station between Kiddy and Droitwich) - I don't think there's any direct service from Manchester to Galton Bridge, so 2 changes would be needed (Wolves and Smethwick or Birmingham and Droitwich)
Robinson
1 Aug 2010
Helensburgh
Ditto every other station on the Snow Hill lines except Worcester Foregate Street, Droitwich Spa, Smethwick Galton Bridge, Snow Hill, Moor Street and Leamington Spa (unless changing at New Street to walk to Moor Street counts as one change...)
Robinson
1 Aug 2010
Helensburgh
Do the terminal branch line stations of Sudbury (Suffolk) and Braintree and other railway stations on these two branches, fall into the category that you quote above?
Yes. Unless someone knows better, I'm pretty certain they require more than one change from Manchester...
richw
10 Jun 2010
Liskeard
I believe there is direct xc from Manchester to penzance so only 1 change for the branches.
Sent from my HTC Sensation Z710e using Tapatalk
gnolife
4 Nov 2010
Johnstone
Nope, Manchester gets XC going as far as Bristol TM (most), Exeter SD (some), Cardiff (daily), Plymouth (daily) and Paignton (twice daily) as all the service to the GWML and Sth Wales
scrapy
15 Dec 2008
There is a summer Saturday service to Newquay, which would cover that branch.
Hartlebury can be reached by changing at Leamington Spa although an overnight wait would be required at Leamington for the one early morning train per day.
