It must write on entry or exit at a gateline otherwise the U1 ticket would give unlimited entry at U1 ....
I looked on Journey Planner (the replacement for RJIS) earlier for this and it quite clearly said that St Pancras - Chelmsford via Stratford International was not a valid route, just as I'd expect.
Well it let me out and back in at St Pancras!
I'd love to hear by what reason it is not valid, for I am unable to see why!
Rail Settlement Plan said:600069 - Customers travelling from Stratford Domestic(sic) station to London St Pancras may not travel via Stratford International. This easement applies in both directions.
I believe it to be valid due to:
(a) there is no +HS1/Not HS1 fare in Avantix, supposedly authoritive for fare data;
(b) the distance travelled is not more than 3 miles longer than the shortest route I can find.
But you don't need to consult that if it's valid as part of the shortest route, surely?Seems pretty definitive to me, even if it is badly worded.
Southeastern have only created "Plus High Speed" fares for 'relevant' flows, and they can't go round creating fares willy nilly where the "base" fares are set by another operator!
The OP is not travelling from Stratford Domestic to London, they are travelling from London to Chelmsford. I can't see how this easement would apply, even if the route is not permitted by the shortest route rule.
Throughout the day there are services that run via Crayford and Slade Green and are advertised as through trains looping between Cannon Street and Cannon Street. This means that you should be able to travel from London to Hither Green via Abbey Wood, but the easement suggests otherwise. But it's a direct train.44
Journeys from or via London and via Crayford and Slade Green, Slade Green and Barnehurst or Barnehurst and Crayford are not valid. This applies in both directions.
This is an issue which has cropped up a few times in the past (originally relating to negative easements on the Fife Circle) and the general consensus seemed to be that they are unenforcable as, following section A of the RG someone would have no reason to read the easements unless they have exhausted all other options within the RG.Throughout the day there are services that run via Crayford and Slade Green and are advertised as through trains looping between Cannon Street and Cannon Street. This means that you should be able to travel from London to Hither Green via Abbey Wood, but the easement suggests otherwise. But it's a direct train.
I was under the impression that Stratford International (aka. STRATFORD INT SE) and Stratford Domestic (aka. STRATFORD LONDON) were two separate stations, and thus a ticket from Stratford Domestic would not be valid from Stratford International.So what we're saying is that the easement which prohibits travel from Stratford Domestic to St Pancras via Stratford International should be unenforceable because the route is permitted by being less than 3 miles longer than the route to Liverpool Street. But the machines and indeed staff at St Pancras did try to enforce the easement.
They are travelling between London St Pancras and Stratford Domestic if they intend going on towards Chelmsford.
Edit: Just checked - higher fares for Chelmsford to London "plus High Speed" ARE also listed, some with various restrictions
Except that U1 is a special ticket closely tied to the valid London terminals and it looks like the OP had a ticket which only allowed Liverpool Street. There might be a higher fare allowing travel via HS1 and St Pancras which would be valid; in the same way that W-on-sea found higher fares from NXEA stations to London. I don't have any fare software or CDs though, so I can't check.I think the Southeastern site supports the OP, since he holds a ANY PERMITTED that goes beyond London Terminals....
http://www.southeasternrailway.co.uk/tickets-and-fares/ticket-types/157/
Supplements
If you have a ticket to London Terminals, an outboundary** Travelcard ticket or you hold a Season ticket, you can upgrade to high speed services by paying a supplement in addition to your current ticket.
For example, a ticket from Margate to St Pancras International would require a supplement in order to travel on the high speed service between Ashford and St Pancras International.
High speed ticket details
The following ticket descriptions entitle you to travel on high speed services:
PLUS HIGH SPEED – this is shown on either a walk up or supplement ticket.
UPGRADE + HS – this is shown on a supplement ticket and must be accompanied by a Southeastern ticket that is not valid on high speed services.
ANY PERMITTED - in the case of long distance through tickets, i.e. destinations beyond St Pancras.
They are not showing in NFM06, at last not on my copy!
But, explain this then...I've just added an update to my post #41 above since you added your reply, Mike.
Given that both Stratford International and Stratford London are both listed as separate stations within the RG, the issue in my mind is, on a non-physical route with three stations, is Stratford International closer or further away from London than Stratford Domestic? Bear in mind that the physical railway infrastructure does not exist in reality! Going on the fares and everything else, I would say that Stratford International is intended to be further away from London and thus a ticket from Stratford Domestic would not be valid there.
....It seems it is going to be cheaper to change at Stratford for Liverpool Street. I contacted the Southeastern ticket office at Ebbsfleet today and received a call back earlier. Their system is allowing to purchase a train only season ticket to Liverpool Street. The person at the office recommends to try the journey with a return ticket first before committing for the season ticket. I also submitted an enquiry on Southeastern website. I will let you know the reply.
That's not a complete list. A Permitted Route isI think you have to look at what a permitted route actually is Yorkie.
The shortest route
On a direct train
As listed in the NRG
Try map HS.I don't know if HS1 is even in the NRG
Agreed. The mapped route between London Group and Chelmsford uses Shenfield as the appropriate Routeing Point for Chelmsford, and is shown on map CO, which permits Shenfield - Romford - Stratford - London Liverpool Street.I know London Terminals to Chelmsford (using Shenfield as the RP) only gives the direct route from Liverpool Street (map CO).
Due to an error, distances do not appear in the current copy of the National Rail Timetable. Assuming that none of the relevant stations have moved in recent months, we know from the previous edition that:is it the shortest route???
It has some logic. If International is deemed further out from London than Domestic then it is ok to change from International to Domestic when going towards London, but not from Domestic to International.
Hairy Handed Fool, thank you for confirming that a Zone U1 (or similar) ticket is considered as an add on to a London Terminals ticket. Please could you tell me, are through fares such as sail-rail and bus links treated in the same way....
Is that a bit of the FRPP the public don't have access to? And which is contradicted by the information given by SouthEastern when the ticket was sold?
a direct service advertised in the National Rail Timetable between the origin and destination printed on the ticket [NRG page A1], or....
the shortest route which has a regular scheduled train service, calculated by reference to the National Rail Timetable [NRG pages A1, A2, F12 and F15], or....
a route which is longer than the shortest route by no more than 3 miles [NRG pages F7 and F9], or....
when origin and destination have a routeing point in common, the route followed by direct trains to and from the common routeing point if the journey is made on those trains [NRG page F7], or....
a mapped route given by the National Routeing Guide [NRG page F9], or....
a route permitted by an easement [NRG page F10]....
unless it is
a route prohibited by an easement [NRG page F10]....
Try map HS....
....This is "a route which is longer than the shortest route by no more than 3 miles". Therefore Chelmsford - Shenfield - Romford - Stratford - HS1 - London St Pancras International is a Permitted Route between Chelmsford and London Group.
But if we are to say that travelling is from the start of your journey to the end of your journey, then surely you are not travelling from/to Stratford Domestic, are you?
As with other terms losely used, "travelling" is not defined by the NRG.
So if the restriction on travelling to/from St Pancras is not covered in the tickets conditions or the NCoC, some questions remain unanswered....
Is the easement even applicable to our journey?
I wonder how much money is spent desperately trying to prevent a handful of people doing St Pancras - Stratford on nearly empty trains? (OK, I'm exaggerating slightly, but I have a point!)
http://www.railforums.co.uk/showthread.php?t=28492&page=2
The problem with the North Kent service is that the time savings are minimal unless you are travelling from Strood, Higham or Gravesend. In fact Gravesend is really the only serious winner on the North Kent stretch. As for Ebbsfleet and Stratford; one is in the middle of nowhere while the other is in the middle of a building site. What do they expect?What has not yet reached expectations are the North Kent Services which are running at well below expectations.
Neither Ebbsfleet or Stratford stations at the present time generate significant traffic for HS1.
Wonder if HS1 loadings would be so healthy if they hadn't slashed the classic route services.
