Manutd1999
Following the news that the ECML recast for summer 2022 has been delayed until at least 2023, I wonder if there is an opportunity to try and simplify the proposed timetable?
LNER proposed this basic pattern for the original 2022 consultation. Times are the departures from Kings Cross.
XX03 Peterborough, Newark, Doncaster, York, Darlington/Durham, Newcastle, Alnmouth/Berwick, Edinburgh + extensions to Aberdeen/Inverness
XX10 Peterborough, Grantham, Doncaster, Wakefield, Leeds + extensions to Harrogate (1p2h)
XX30 York, Newcastle, Edinburgh
XX33 Stevenage, Grantham, York, Northallerton, Darlington, Durham, Newcastle
XX40 Stevenage, Newark, Doncaster, Wakefield, Leeds
XX47 Peterborough, Retford, Doncaster, York
or
XX47 Peterborough, Grantham, Newark, Lincoln
There were aspirations to extend the XX47 to Middlesborough and add an extra Leeds service every 2 hours, presumably sharing a path with the open access operators.
The timetable achieves a reasonable balance between long-distance services and connectivity, but the result is a complex, two-hourly pattern. However, I think this could be adjusted to a more consistent hourly pattern relatively easily. Something like this:
- The XX03 calls at both Darlington and Durham each hour.
- Cut the 3rd hourly Newcastle service (XX33) to instead terminate at Newark, with extensions to Lincoln.
- The XX47 'stopper' operates to York each hour.This could still be extended to Middlesborough as planned.
XX03 Peterborough, Newark, Doncaster, York, Darlington, Durham, Newcastle, Berwick/Alnmouth, Edinburgh + extensions to Aberdeen/Inverness
XX10 Peterborough, Grantham, Doncaster, Wakefield, Leeds + extensions to Harrogate/Bradford (1p2h)
XX33 Stevenage, Grantham, Newark + extensions to Lincoln
XX40 Stevenage, Peterborough, Doncaster, Wakefield, Leeds
XX47 Peterborough, Retford, Doncaster, York + extensions to Middlesborough
A few of the winners and losers:
+ All major stations get a consistent hourly service, compared to the proposed 2-hourly pattern.
+ The vast majority of connectivity is maintained.
+ Paths are consistent each hour, which could give some extra flexibility for other services north of Doncaster.
+ Some units are probably saved by terminating the XX33 at Newark rather than Newcastle (?)
- Newcastle doesn't gain the 3rd hourly service. However, is this really needed? Leeds/Sheffield/Nottingham etc all manage with 2ph to London.
- Northallerton loses service to London, although it is still served by TPE and/or XC with connections at York.
- Grantham loses service to York and Newcastle, but still has connections at Doncaster and Leeds.
I would also scrap plans for an extra Leeds train every 2-hours (via Hambleton). It seems like an added complication for minimal benefit. The Bradford and Harrogate extensions could be achieved using the existing 2ph service. This would also leave 2x spare paths for open access operators each hour, giving room to grow these services as required (e.g. hourly Hull, or extra 'Luma' trains to Edinburgh).
or
