Abbreviations and acronyms
NKBLTD
19 Oct 2009
Bristol
Some easy, some not so easy. The whole answer please, not just what it means.
WON
PON
EROS or ESR
TSR
TPWS
ATWS
AWS
RETB
RIAB
ATP
APT
SPAD
SPATE
TOWS
LOWS
PEE WEE
COSS
AOD
Good luck
GB
16 Nov 2008
Somewhere
WON Weekly Operating Notice
Contains various information such as TSRs and engineering work
Also contains miscellaneous items
PON Peridodic Operating Nortice
Contains various information such as changes to rules and regulations and changes to the Sectional Appendix
EROS or ESR Emergency Speed Restriction/Emergency Reduction Of Speed
An emergency reduction in line speed NOT published in the WON
TSR Temproary Speed Restriction
A reduction in the line speed published in the WON
TPWS Train Protection & Warning System
Where fitted, automaticly applies the trains brakes if either the train approaches a signal (showing Red) or buffers too fast or passes a signal at danger
ATWS Automatic Train Warning System
Presumably it is a warning system for track workers operated by any train operating certain track circuits?
AWS Automatic Warning System
Gives an audable and visual indication to drivers about the signal they are approaching. Failure to acknowledge a warning will result in the brakes automaticaly applying
RETB Radio Electronic Toeken Block
A method of Signalling trains.
RIAB Dont Know, unless you are thinking or RAIB? Railway Accident Investigation Branch
Self Explanatory
ATP Automatic Train Protection
APT
SPAD Signal Passed At Danger
Self Explanatory
SPATE Speed Previously Advertised Terminated Early
Where an TSR has been withdrawn early, any board that shows the temporary speed will be changed to show /
TOWS Train Operated Warning System
LOWS
PEE WEE
Dont know what it stands for but I think it is the horn used by lookouts?
COSS Controller Of Site Safety
Responsible for safety when two or more people are lineside/on or near the line.Responsible for setting up a safe system of work and to brief staff
AOD
Good luck
royaloak
11 Oct 2009
today I will mostly be at home decorating
APT advanced passenger train, developed in the 80s before the technology was sold to Italy and we end up with the pendos
LOWS locally operated warning system, the lookout( might be round a corner) has the controls to warn the gang
12 Nov 2008
S+C= Settle and Carlisle
SPT= Strathclyde Public Transport
ATOC- Association of Train Operating Companies
GB
16 Nov 2008
Somewhere
Tecnically you are right with the first two, but I was looking for something slightly different. (Think track)
GB
16 Nov 2008
Somewhere
A big gold star for you royaloak;):D They were indeed what I was looking for.
NKBLTD
19 Oct 2009
Bristol
ATWS= Automatic TRACK warning system, train was a miss quote is some publications.
Lookout operated warning system -LOWS
No idea what that is
Heres some more to add to your list;)
ADD
AOM
S&C
C&W
CWR
DSD
AOLC
ATOC
CDL
COSHH
DOO
SPT
All very easy;)
CWR= Continous welded rail
DOO= Driver only operated
ATOC= Association of train operating companies
DSD, i think is a some kind of driver vigilance device?
Hydro
5 Mar 2007
AOM - Area Operations Manager
AOLC - Automatic Open Level Crossing
ADD - Automatic Dropper Device
S&C - Switches and Crossings
CWR - Continuous Welded Rail
AOD - Auxiliary Operating Duties
PeeWee is a lookout alarm system that's so named due to the noise it makes. No longer used IIRC. ATWS is a warning system of alarms and lights activated by a treadle system. TOWS is the equivalent track circuit operated system. Both are used at fixed locations. ATWS systems can be temporarily set up at long term sites however.
driver9000
13 Jan 2008
DSD - Drivers Safety Device.
A pedal which the driver must keep pressed while the train is in motion (some older stock has it incorporated into the power handle). The Vigilance device if fitted is incorporated into the DSD and if no major control (power, brake, AWS) is moved for approx 60secs, the alarm sounds and the driver must acknowledge by releasing the DSD and pressing it again otherwise the train is brought to a stand automatically.
NKBLTD
19 Oct 2009
Bristol
AOCL it should be, Automatic open crossing, locally monitored.:D
O L Leigh
20 Jan 2006
In the cab with the paper
ADD - Automatic Dropping Device
Automatically drops the pantograph if it becomes damaged (e.g. loss of carbon strip or pan head) or goes over-height.
AOM - Area Ops Manager
Someone further up the ladder than me.
S&C - Settle and Carlisle...?
Too easy...?
C&W - Dunno
CWR - Continuously Welded Rail
Should be self-explanatory.
DSD - Driver's Safety Device
Not like vigilance at all, though vigilance can be incorporated into it. It's like the deadman's handle of old, though these days it's more likely to be a pedal.
AOLC - Shouldn't this be AOCL...? Automatic Open Crossing Locally Monitored
An open level crossing (e.g. one without barriers) operated automatically by treadles or by a driver's plunger, that is not under the direct control of the signaller. Traincrew are required to observe a flashing white light on approach to the crossing to see that the crossing equipment is operating correctly.
ATOC - Association of Train Operating Companies
Kind of a trade body that represents passenger train operators.
CDL - Central Door Locking
What stops the doors on slammers swinging open.
COSHH - Control of Substances Hazardous to Health
Rules and regs for looking after hazardous substances.
DOO - Driver Only Operation
What I do.
SPT - Signal Post Telephone
Direct comms with the Bobby at the signal.
O L Leigh
GB
16 Nov 2008
Somewhere
Very good O L Leigh. The missing one was Carridge & Wagon...basicly someone who is trained in viehicle inspections.
your turn:)
Wyvern
27 Oct 2009
1/ iecc
Integrated Electronic Control Centre - An electronic signalling system
2/ ssi
Solid State Interlocking - ditto
3/ rri pass
4/ los pass
5/ mas
Multiple Aspect Signaling - Colour light signals with different lamps for the differenst colours
6/ nrn
National Rail (?) Network - One of the cab radio systems
GB
16 Nov 2008
Somewhere
LOS - Limit Of Shunt
Shunting trains not to pass beyound this point without authorisation from the signaller
Wyvern
27 Oct 2009
RRI is route relay interlocking - signalling again
What about RRAP?
PAINT and ROTTEN You're sure you haven't made these up?
Acronyms always remind me of Tommy Handley and ITMA - any guesses for DWTWWASBE? :lol:
Hydro
5 Mar 2007
Always though LWR was CWR prior to welding up. I'll throw in 120ft.
