Are Arriva enhanced then? I'm currently sitting in a talent pool so debating whether to go for this.Please answer this Question: If you fail to attain enhanced pass marks with Arriva, would your national pass mark be then wiped off your profile?
From what i have read, yes.Are Arriva enhanced then? I'm currently sitting in a talent pool so debating whether to go for this.
Hmm not sure if it's worth the risk then as I've read a few times that your current score gets wipedFrom what i have read, yes.
Apply and if you get shortlisted ask them what tests (probably only Group boardon and the VSE) you have to sit.Hmm not sure if it's worth the risk then as I've read a few times that your current score gets wiped
Oh ok thank youArriva are enhanced . If you fail to enhanced , but your score is national standard then you are ok , it is only wiped if while trying for enhanced you dont score high enough for standard.
Hi Just applied for this , I did the OPC assessments with Freightliner and was told that these were enhanced, I passed these will they count towards Arriva or will have to retake these for Arriva?
Wow. I think i will just stay patient and wait for medical/start date with the TOC that i passed assessments for.Arriva are enhanced . If you fail to enhanced , but your score is national standard then you are ok , it is only wiped if while trying for enhanced you dont score high enough for standard.
Not since approximately end of 2017GTR pass marks enhanced ?
K. ThanksNot since approximately end of 2017
Same here. Sent off an email to see what can be done...Trying to apply. Anyone else having a problem when you hit the submit button? Mine just takes me back tk the beggining with all the data lost!
The Trainee driver positions are only for New Cross GateLooking at the advert, it states. You will need to live in proximity to the depots.
Is this the general 1 hour rule.? As I’m 1hour 1 minute from Willesden.
Let's hope they respond before advert closes. .Same here. Sent off an email to see what can be done...
There are compatibility issues with Apple devices and also with the Firefox browserLet's hope they respond before advert closes. .![]()
Im using Firefox at the moment so maybe that's the issue. Will try on another browser.There are compatibility issues with Apple devices and also with the Firefox browser
I didn't have this problem last year.
check agaiinI'm pretty certain yesterday when i applied at said Various New cross gate and willesden
check agaiin
OK i'll tell you, because it was a mistake. They are only recruiting for NXGNo need i have a screenshot from my application yesterday and it says various, new cross and Willesden on it, why they have changed it today to just New cross I have no idea
Application now submitted, using different browser.Im using Firefox at the moment so maybe that's the issue. Will try on another browser.
Thanks!
