Bus max load display. Still mandatory?
fandroid
9 Nov 2014
Hampshire
I realise that just about every bus I've been on has had a publicly displayed notice saying what the max nos. of seated and standing passengers are. I'm on this Stagecoach South bus and I cannot see one. Was it mandatory and is it still so now?
Surreyman
29 Jan 2012
Don't the answer to that one, going slightly off on a tangent, I regularly travel on Stagecoach E200s and looking at the seated/standing/wheelchair capacity combinations, I think that the maximum standing numbers allowed would be physically impossible to exceed on an E200.
duncombec
3 Sep 2014
Aren't the maximum capacities worked on a purely weight calculation basis, not physical space?
They are in a variety of positions - you may find it is tucked away above the driver's head, only visible if you duck below assault screen fittings. Above the door is another common placement nowadays.
richw
10 Jun 2010
Liskeard
Yes, there is a legal weight you treat each person as whether they are 50kg or 150kg. The given weight includes a bag for each passenger at an assumed weight too. Going back it used to be the case that 3 children only counted as 2 people, but I can’t find reference to that in current rules.
You’ll find small e200mmcs have a ridiculous standing capacity due to having the same chassis and max gross weight as their bigger versions.
SSmith2009
20 Dec 2021
East Midlands
the GB Kite electric single deckers that First have in Leicester have a standing capacity of 40
**EDIT**
the max standing capacity is 57 overall capacity of 90
busken
25 Nov 2016
It always surprises me that buses quite rightly have a maximum capacity due to weight issues, but trains have no limits at all!
Towers
30 Aug 2021
Quite simply, you can’t police it on a train and so it would have zero value. Trains are also a lot heavier duty than a bus, and they generally won’t exert the same potentially sudden forces on passengers as a road vehicle might do; for example when cornering or if it is necessary to brake sharply.
WestCountry
31 Dec 2010
Cambridge, UK
Trains are designed to carry 7 passengers per m² of standing space, plus those seated, which is about as many as can physically fit so the 'limit' is self-enforcing.
In the current issue of Modern Railways, Ian Walmsley mentions that being an issue when removing seats from 455s to create more standing space - the loads on the bodyshell/bogies/axleboxes had to be recalculated and were right on the design limits.
Deerfold
26 Nov 2009
On an occasion when we were sardine packed at Kings Cross after several cancellations the driver announced we wouldn't be going anywhere unless some people got off as the train was overloaded.
jp4712
1 May 2009
Yes, it has been mandatory since the passing of the Road Traffic Act 1930. It’s also mandatory to display the unladen weight on the outside, along with the address of the vehicle’s operator (known as the legal address).
The relationship between weight and number of passengers is twofold: firstly the gross weight (including passengers) is limited by law, and secondly the tilt test must be passed with weights to represent passengers strapped to seats (upstairs only in the case of a double decker). There have been occasional examples in the past of buses having to have the seating capacity reduced, because of an inability to meet one of these requirements.
joieman
18 Feb 2024
Loughborough
Slight tangent, I rode on a Wright Pulsar 2 (63-plate, I think) of Arriva's on the 16 and noticed that the maximum total capacity was the same (77) whether more or fewer people were standing or sitting.
TravelDream
7 Aug 2016
Do you know what that weight is?
The ones airlines use is comically low for 2024.
An adult plus their hand luggage is taken to be 84kg. If it's a holiday charter, the weight is (for whatever reason) 76kg.
A child, plus their hand luggage, is 35kg. Even for holiday charters.
Now go on the average Jet2 flight to Alicante and tell me the average adult along with their hand luggage is 76kg. If you think so, I have magic beans to sell...
Qwerty133
7 Oct 2012
Leicester/Sheffield
Which given it is based entirely on weight makes absolute sense (although I think at one point a wheelchair user counted as 2 or 3 people for the calculation).
Of course in many cases it will not be physically possible to get the full number of standing passengers on board.
plugwash
29 May 2015
My understanding is that on trains they simply assume it will be crush-loaded and design accordingly.
IIRC when they did the 769 conversions they had to add seats to reduce weight (seating gives less "crush-laden weight" for a given area than standing passengers does)
