Beveridges
Last night I used TRUST to count up how busy the busiest stations in the UK for freight were in a given 24 hour period. I only counted the freight which actually ran. The cancelled & Q stuff was ignored! I counted light engine moves, Track Machines and Charters as "Freight". These were the results:
Freight Countup 06 - MAR - 14
Barnetby - 120
Nuneaton - 118
Stafford - 115
Willesden Junction - 104
Acton Bridge - 101
Tamworth - 99
Doncaster - 90
York (Colton Junction) - 89
Retford - 86
Didcot - 78
Water Orton - 77
Newport - 73
Peterborough - 70
Trimley - 69
Carlisle - 65
Harrow & Wealdstone - 64
Basingstoke - 61
Eastleigh - 57
WBQ - 57
Knottingley - 57
Stratford - 56
Leamington Spa - 55
Chesterfield - 50
Toton Yards - 48
Preston - 42
Loughborough - 42
Acton Main Line - 36
Crewe - 36 (Station), 98 (Avoider)
Kensington Olympia - 34
Peak Forest Yards - 27
Note: Willesden is difficult to measure as you have to combine different reporting points on TRUST to cover as much of it as possible. The total is probably slightly higher than 104.
Note: Tamworth includes both the high level & low level as they are both technically part of the same station.
Note: Barnetby appeared to be a quiet day. I have counted up to 192 freights here in 24 hrs.
Some stations scored particularly high due to the amount of freight which runs at night. For my next set of statistics I'm only going to count the freights which run between 06:00 - 23:00 as these are the only ones which really matter to most trainspotters & see how the statistics appear then. Retford, Stafford, Acton Bridge, Preston & Nuneaton in particular are a lot less busy in the day than night.
Barnetby - 120
Nuneaton - 118
Stafford - 115
Acton Bridge - 101
Tamworth - 99
Doncaster - 90
Retford - 86
Didcot - 78
Water Orton - 77
Newport - 73
Peterborough - 70
Trimley - 69
Carlisle - 65
Basingstoke - 61
Eastleigh - 57
WBQ - 57
Knottingley - 57
Stratford - 56
Leamington Spa - 55
Chesterfield - 50
Toton Yards - 48
Preston - 42
Loughborough - 42
