Busiest stations in UK by number of train departures?
etr221
10 Mar 2018
Can anybody point me at statistics (or provide the figures) showing the busiest stations in the UK (TfL, National Rail or whoever), or even globally, by number of trains (departures/arrivals/movements per day/year)? (All those readily available are by passengers).
At a guess I would suggest King's Cross LU (on four lines) for the top spot, but it is a guess - I've no real idea whether it is or not, or by what margin.
(By way of comparison, I had no difficulty in finding that the world's busiest airports (by departures) are in the 500-1000 flights per day range)
Krokodil
23 Jan 2023
Wales
Surely Clapham Junction has the most movements at circa 118 departures per hour.
fkofilee
19 Jul 2015
CLJ / Clapham rules the roost for this. Southern, GX, SWR and London Overground depart from here.
norbitonflyer
24 Mar 2020
SW London
Not sure if its still the case, but Birmingham New Street used to have the most arrivals and departures, but if you include trains that pass through non stop, Clapham Junction has more movements.
Sultan
6 Mar 2019
Copied to excel - a bit of reformatting but filtering on any station with more than 400 departures in either local or express column:
StationLocalExpressOtherTotal
BIRKENHEAD HAMILTON SQUARE (MEDIUM INTERCHANGE)
417​
417​
BOND STREET EL (LARGE INTERCHANGE)
662​
662​
CANADA WATER (SMALL INTERCHANGE)
584​
584​
CANONBURY (SMALL INTERCHANGE)
615​
615​
CLAPHAM JUNCTION (MEDIUM INTERCHANGE)
1,405​
515​
1,920​
DALSTON JUNCTION (SMALL INTERCHANGE)
440​
440​
EAST CROYDON (MEDIUM INTERCHANGE)
51​
755​
1​
807​
FARRINGDON (LARGE INTERCHANGE)
930​
292​
1,222​
GATWICK AIRPORT (MEDIUM INTERCHANGE)
3​
592​
3​
598​
HAGGERSTON
584​
584​
HIGHBURY & ISLINGTON (MEDIUM INTERCHANGE)
684​
684​
HOXTON
584​
584​
HYNDLAND (SMALL INTERCHANGE)
425​
1​
426​
LEWISHAM (MEDIUM INTERCHANGE)
516​
2​
518​
LIVERPOOL CENTRAL (MEDIUM INTERCHANGE)
449​
449​
LIVERPOOL JAMES STREET (SMALL INTERCHANGE)
418​
418​
LONDON BRIDGE 906 6541,560
LONDON LIVERPOOL STREET (LARGE INTERCHANGE)
929​
208​
1,137​
LONDON PADDINGTON (LARGE INTERCHANGE)
553​
237​
1​
791​
LONDON WATERLOO (LARGE INTERCHANGE)
480​
159​
639​
LONDON WATERLOO EAST (LARGE INTERCHANGE)
408​
256​
664​
MOORFIELDS (MEDIUM INTERCHANGE)
550​
550​
PARTICK (SMALL INTERCHANGE)
425​
1​
426​
PECKHAM RYE (MEDIUM INTERCHANGE)
464​
464​
ROMFORD (MEDIUM INTERCHANGE)
428​
428​
ROTHERHITHE
584​
584​
SHADWELL (SMALL INTERCHANGE)
584​
584​
TOTTENHAM COURT ROAD EL (LARGE INTERCHANGE)
662​
662​
SHOREDITCH HIGH STREET
584​
584​
STRATFORD (LONDON) (MEDIUM INTERCHANGE)
626​
268​
894​
SURREY QUAYS (SMALL INTERCHANGE)
584​
584​
VAUXHALL (MEDIUM INTERCHANGE)
763​
45​
808​
WAPPING
584​
584​
WHITECHAPEL (MEDIUM INTERCHANGE)
1,246​
1,246​
WIMBLEDON (MEDIUM INTERCHANGE)
557​
36​
593​
Taunton
1 Aug 2013
If Stratford included the TfL lines, which unlike Kings Cross etc are all mixed in on the surface with the NR trains and have common passenger flows and gatelines, that might give Clapham Junction a run for its money.
etr221
10 Mar 2018
@Sultan Not sure what happened to London Bridge... (and others which might be missed)
Note Farringdon and Whitechapel beat Liverpool Street...
It all comes down to thinking about what is and isn't counted (and does that match what should be?), and what is the difference between one station and two (or more)... And that reveals the surprises (that perhaps shouldn't be); and (given some LU trains are there, and others aren't) how incorrect what comes from it is...
Taunton
1 Aug 2013
Both Liverpool James Street and Birkenhead Hamilton Square are effectively wayside stations, with low entrance/exit numbers. James Street does not have any interchange at all, to give it any such a status is wrong.
Similarly, just stabbing at examples, suggesting Wapping has 85% of the traffic of Tottenham Court Road Elizabeth Line, by whatever method of counting, is laughable. Likewise saying Hamilton Square has as much "interchange" as East Croydon :( .
etr221
10 Mar 2018
This thread is about numbers of departing trains, not number of passengers... I shall leave it others to raise the question of which stations have the highest/lowest ratio of trains to passengers.
And the "interchange status" is purely an element of the data used by journey planners to decide where to prioritise changes, if changes are possible at multiple stations for the same departure and arrival times.
The exile
31 Mar 2010
Somerset
Intrigued as to what counts as “other”! Guess at Paddington it might be the Night Riviera but goodness knows what it is elsewhere!
Krokodil
23 Jan 2023
Wales
Sleepers, ships, service buses, replacement buses and LU/metro are counted separately.
ATrainSpotter
16 Oct 2022
FARRINGDON (LARGE INTERCHANGE)9302921,222
Why is Farringdon considered a large interchange up there with gargantuan stations like Waterloo, London Bridge ect.? It's small!
Parjon
27 Oct 2022
St Helens
James Street does have interchange status, from outbound to inbound Wirral Line. ~3m passengers (Hamilton Sq 2m).
I am confused. How can Moorfields have more departures than Liverpool Central?
Djgr
30 Jul 2018
Because Moorfields has all the Northern and Wirral line departures of Liverpool Central but in addition has the Northern line departures that terminate at Liverpool Central.
Hadders
27 Apr 2011
Thameslink and the Elizabeth Line both serve Farringdon along with the Met/Circle/H&C Underground Lines.
A complete change to the pre-Thameslimk days.
ATrainSpotter
16 Oct 2022
Yes I know, I'm a regular commuter through there. I guess its measured with how many destinations trains go to rather than the station size itself?
11 Jan 2015
Counting methodology matters. If London Underground were to be included somewhere like Stratford would be much higher up, even more so if the DLR was as well.
richw
10 Jun 2010
Liskeard
Since opening of the Elizabeth line, Farringdon is the suggested routing between stations west of Paddington to Gatwick. It was the quickest route by some time when I travelled Cornwall to Gatwick a couple of months back.
Sultan
6 Mar 2019
Oops - must have missed that one when filtering. It was a rush job! I've inserted it (didn't know that was possible)
Bus Replacement Services on that day I think
BigB
20 Dec 2018
Scotland (ECML) to Essex now routes via EL instead of the tube. Very simple journey too!
richw
10 Jun 2010
Liskeard
It’s a definite game changer arriving at Paddington, but has changed flows. Previously would have been tube to London Bridge or victoria to head for Gatwick, or change at Reading. Time wise EL to change at Farringdon has shaved 30 mins or more off in reality.
