Bypassing Tamworth and Lichfield T.V. on the WCML?
11 Jan 2011
All around Sloane Square
Hello,
I wasn't sure where to post this, so here it is.
Is it possible for a train, going up or down the WCML, pass through Rugeley Trent Valley, avoid Lichfield Trent Valley and Tamworth but then pass through Nuneaton, or vice versa?
I ask this after seeing timings for trains and tours that appear to avoid Tamworth and LTV - or are the timings for these stations simply not listed to save space?
For example, here's part of the timings for The Cumbrian Mountain Express, next wednesday:
Nuneaton 0807-0810
Amington Junction 0821
Lichfield North Jn (Ll) 0827
Rugeley North Jn 0832
Colwich 0835
Stafford 0841-0857
....I'd normally go to Lichfield T.V. to phot a train on this route, and will eventually do it at Tamworth, but will the train even call at/pass through those stations?
Sorry if this is a ramble, I can't concisely word anything, ever.
Cheers!
sprinterguy
4 Mar 2010
Macclesfield
According to those junction descriptions then the train will pass through Tamworth and Lichfield stations, although if it uses the fasts then it will not actually pass through a platform road, which may be a possible explanation why the stations are not listed, but the nearby junctions are instead.
ilkestonian
6 Dec 2009
The Potteries
Hello,
No, will be WCML. Realtime trains shows that the CME is routed on the slows through the area, from just north of Rugby as far as Colwich, and given the times between the various timing points, it would have to be direct via the WCML even if there were an alternative...
They will not usually show passing locations unless they are timing points. So it looks to me that the stations you mention are not passing points for non-stop trains.
Timing points are detailed in the Rules of the Plan.
Tamworth and Lichfield TV are not mandatory timing points as they aren't points of conflict or cause any other timing issues. Only trains that stop there are timed.
Boothby97
24 Apr 2011
Grimsby
Hello,
Nuneaton 0807-0810
Colwich 0835
Stafford 0841-0857
Cheers!
Lichfield North Jn is north of Lichfield TV and Amington Jn is of Tamworth.
Thanks, Sam
Nuneaton 0807-0810
Colwich 0835
Stafford 0841-0857
This is the new TV4 route, and there are no crossovers from fast to slow between Amington Jn and Lichfield North Jn.
If you are on the fast you can't access Tamworth or Lichfield stations anyway.
