Changing ends in loco
Stan63
20 Apr 2014
Paisley
I was just watching a driver changing ends in a class 66 loco and was wondering if they always have to leave the loco to do this or whether the driver could walk through from one end to the other. The question could apply to any main line loco.
Stan
father_jack
26 Jan 2010
Going through the engine room is a bit noisy and has hot spots you could lean against. But the ballast shoulder at the edge of the track may be unsafe so it might be the only way.
Islineclear3_1
24 Apr 2014
PTSO or platform depending on the weather
I don't know about 66's specifically but certainly in the BR-era locomotives, crew could walk from one end of the loco to the other without getting out
Perhaps the driver wanted some "fresh" air because of the heat inside the loco
Perhaps the noise in the engine room was too loud and the driver didn't have ear protection
Could be any reason
Stan63
20 Apr 2014
Paisley
Thanks. I've seen the driver change ends in the pouring rain on the webcam outside the station at Crewe and thought it would be easier to walk through if he could.
Stan
martin2345uk
21 Sep 2011
Essex
I always get out even if it's raining, walking through the engine room right next to the engine when it's running is not a pleasant experience!
D6975
26 Nov 2009
Bristol
Low emission 66s can be recognised by the extra door part way down the body on one side. IIUI they have two dead end 'walk throughs', you can't get all the way from one cab to the other. This is due to the extra gubbins inside compared to a 'normal' 66.
Whistler40145
30 Apr 2010
Lancashire
Without being rude and discriminating, a rather rotund driver could find it difficult squeezing through the rather tight space in the engine room
GB
16 Nov 2008
Somewhere
The dead end walkway is only on one side of the loco and only accessible from No2 end. The other side (the non battery isolation switch side) is full through access...and I'm pretty sure that's the same for all 66's
Stan63
20 Apr 2014
Paisley
Thanks for all the information. I'll keep a close eye any time a driver changes ends on a loco and see if there is ever a time they walk through.
Stan
