GWR Class 800
SpacePhoenix
18 Mar 2014
Just looking at the pic, it looks like they could never be run in 3rd rail teritory (I think that step would be well foul of the 3rd rail) so I can't see XC ordering any (at least for their route down to Bournemouth)
NotATrainspott
2 Feb 2013
The IEP specification demanded that the bi-mode trains be able to run in self-powered mode over third rail and 1500V DC overhead (Tyne and Wear, Sunderland) electrified lines.
TheKnightWho
17 Oct 2012
Oxford
In fact, I'd expect XC and the MML to both order them for their entire fleets. I imagine we'll see a lot of class 800s over the coming years, which will slowly be converted to class 801s over time as electrification progresses.
This is effectively the HST replacement, after all.
395/Javelin has a step in the same place, it is just above the shoe beam.
TheKnightWho
17 Oct 2012
Oxford
Was there anything in the spec about potential 3rd rail compatibility? Obviously not for the FGW or EC sets, but for any potential orders. Or would they not be considered IEP, but a derivative of it also based on the AT300 model?
D365
29 Jun 2012
Apparently so:
WatcherZero
25 Feb 2010
Some journalists suggesting the FGW order may be on DFTs behalf and some of them may actually be destined for Cross Country instead.
NotATrainspott
2 Feb 2013
Sorry - I meant self-powering on the 3rd rail, as Javelins do.
Would there be much point? If the track allowed, bi-mode Class 800s would be able to run faster in self-powered mode than they would using third rail shoes (limited to 160km/h). There isn't much point buying an AT300 derivative for the Manchester-South Coast CrossCountry services when they would be limited to traditional speeds on the WCML, and thus the rolling stock may as well have a flat end like a Class 444 or the new AT200s for Scotland and the extra capacity and flexibility that brings.
D365
29 Jun 2012
Fair point about the third rail, but the CrossCountry 221s have their tilt function removed anyway.
D365
29 Jun 2012
Interior shots of what exactly?
See between my posts above! WatcherZero explains.
Now, if this was IEP specification, I'd have hoped they would name it as Class 151 'SNES' for 'Super Nintendo Express Stock' :D
TheKnightWho
17 Oct 2012
Oxford
True, although I can't see any 3rd rail track being upgraded to support speeds higher than 100mph due to the high capacity constraints on those parts of the network, and the minimal benefit if just XC services would use it.
And whilst that's true for the WCML section, you're forgetting that most of the route is away from the WCML anyway, and XC services than run the route currently don't tilt so there'd be 0 disadvantage over current services.
SpacePhoenix
18 Mar 2014
If the SWML was eventually converted to AC and the line to Exeter via Salisbury was converted to double track would the increase in max line speed be enough to justify the use of an 800 or 801?
9 Jul 2011
The Javelin (Class 395) is itself that AT300 derivative.
jimm
6 Apr 2012
Yes. I know.
What I'm getting at is whether it is possible to fit a 3rd rail pickup to an IEP derivative. I'm not sure how I can make that any clearer.
Given that the 800/801 are based on a 395 and the bogies appear to share the same basic design then, yes, you could probably fit conductor shoes if you moved the step to the position on a 395 which is a bit higher and further back on the bogie - but it's not going to happen.
TheKnightWho
17 Oct 2012
Oxford
I meant for any potential XC orders, which certainly are in the running. I'm not really sure why you're ruling it out, other than pessimism.
Noddy
11 Oct 2014
Does anyone have a handy link or breakdown as to what the time savings will be when they are introduced, and also if/when the ECML and GWML are upgraded for 225kph?
