Could we ever see a rail link to Bristol Aiport?
tigerroar
30 May 2010
Gloucester
Has there ever been any suggestion of connecting it to the national rail network? It seems to be an equal distance to the mainline as Manchester is.
I suspect building that busway in through the south of the city has pretty much killed any chance anyhow :(
28 Apr 2015
I don't know the story behind this, although I'm sure that it's come up on this forum before. However, as a very regular user of Bristol Airport, I can provide you with one fact counting against a rail link.
The altitude of the GWR Main Line at the point that it's crossed by the A370 at Long Ashton is 100ft. The altitude of the airport terminal is 600ft, there's a near 100ft drop right in front of it apart from anything else. The landscape in the short distance between the two points is complicated to say the least.
Others may be able to add more, but that's the physical geography covered...
AndrewE
9 Nov 2015
That the current airport is there is only an accident of history. It could probably have been any one of half a dozen other ex-WW2 airfields in the region.
The questions that need asking are what is the UK transport strategy (A: we haven't got one) How much many regional airport hubs can be reconciled with a commitment to reduce CO2 emissions (not many I suspect) and how many individual journeys (or overall transport of "stuff") the earth can support?
Mag_seven
1 Sep 2014
here to eternity
Filton would have been a good call right next to the London-South Wales and Birmingham - Bristol lines and the M4 and M5 motorways to boot.
S-Bahn
2 Nov 2018
Can't see Bristol Airport ever being connected with heavy rail. Maybe in the future if they adopt a Metro Tram-train system (like South Wales is going to pursue), you might be able to get a spur to the airport with a mixture of rail and street running - but unlikely.
That said, Bristol Airport is crying out for decent connections to the M5, Bristol and the rail network.
In the age of the smartphone sat-nav, many motorists are being re-directed onto narrow country lanes and through the villages to get between the M5 and the airport - because they haven't built a by-pass linking the motorway and airport.
Madness.
tigerroar
30 May 2010
Gloucester
I had an inkling that Google Earth wasn't being completely honest with me. Maybe approaching from the east could help alleviate the gradient ;)
Envoy
29 Aug 2014
Bristol Airport is in a terrible position regarding transport links. If the powers that be had any sense, they would have made Filton the main airport - which would have allowed direct rail access and the port where several mainlines meet - as do the motorways. (Filton was rejected because they went and built all that new housing in north Bristol along with the Cribb’s Causeway retailing area just north of the airfield). Failing that, a new airport should have been built near the Severn Bridges. (The site of the new ‘Wave’ surfing centre near Easter Compton would have been ideal or that of the Llanwern steelworks on the Welsh side). So, with the combined population of Bristol, Newport & Cardiff plus all the more outlying areas such as Bath, the valleys, Swansea, Gloucester, Cheltenham etc. all having easy access, it would surely have been better than the situation we have now with Bristol and Cardiff Airports?
I now hear that the mayor of Bristol wishes to ban diesel cars from the central area including the A4 route through the gorge. This is of course the main route from the M5 at Avonmouth to the Airport.
https://www.cleanairforbristol.org
If this decision is made, then everybody with a diesel car coming from the M5 & M49 (from south Wales) and wishing to reach the Airport will have to come off the M5 at J19 and use the backroads via the village of Flax Bourton.
See map:>
https://www.google.co.uk/maps/place...d7088e6!8m2!3d51.4208878!4d-2.7092457!5m1!1e1
It is possible that Cardiff Airport may get a direct rail link from the Vale of Glamorgan Coast Line. Even as things stand now, a bus links Cardiff Airport with the nearby station at Rhoose. The only problem is that trains on this line between Cardiff Central & Bridgend (for west Wales) are every hour. The plan is for it to become half hourly in 2023 - which is regrettable as much new housing has gone up at Rhoose and Llantwit Major and the line also forms the quickest and shortest route between Swansea / west Wales and Barry - as well as the Airport.
I think having the Avonmouth line running through the site would have counted against it.
Are you suggesting that a new bypass is needed (at great cost to the public purse and contrary to environmental objectives) simply because satnavs aren't appropriately programmed? Surely this problem (and many others) could be solved more cheaply by better regulation of how satnavs work (though I note the point about the diesel ban which is a separate issue).
It's likely that a medium-sized regional airport won't attract enough rail passengers to justify a new branch line and an extra service to run on it, though it might justify a new station on an existing route if there was one near enough. Manchester is a little different in that the rail geography and service pattern made it relatively easy to serve by train (though recent problems on the city centre rail network suggest it may now have been pushed too far) and because it has a greater range of flights than other airports in the North so attracts passengers from further afield.
tigerroar
30 May 2010
Gloucester
Just going back to the local topography for a moment, and at the risk of getting my knuckles rapped for talking about roads, it's always puzzled me why they chose to build the M5 high upon a ridge instead of the plain down below as the motorway heads south after Bristol.
Llanigraham
23 Mar 2013
Powys
Because the valley below the raised section is basically a bog.
nick.c
12 Mar 2012
In the age of the smartphone sat-nav, many motorists are being re-directed onto narrow country lanes and through the villages to get between the M5 and the airport - because they haven't built a by-pass linking the motorway and airport. Madness.
Not just "narrow country lanes" but single track lanes in places. As you rightly say "Madness".
randyrippley
21 Feb 2016
I still think the airfield at Weston-super-Mare would have been the better one to develop rather than Lulsgate.
Railway, M6, A38 all adjacent. Would probably have needed extending to take passenger jets but the transport links were better than the alternatives
S-Bahn
2 Nov 2018
People have a general right to drive on any public highway and take any route they like, subject to road restrictions (like one-way, no right turn, no vehicles over a certain height or weight etc.) Therefore you mitigate that by building trunk routes and bypasses etc to allow traffic to flow freely.
Roads like the A4 and A369 are already clogged up with traffic going into and out of Bristol itself, hence the reason Google and Waze take motorists for the airport away from those roads, even sometimes late at night.
A free-flowing dual carriageway capped at 50mph with speed average cameras from the M5 to the airport would have less of an environmental impact than the same traffic having to constantly accelerate, brake and change gears going through country lanes and multiple villages like Flax-Bourton.
There may be a case for some improvement, and looking at the map there indeed isn't a decent route to/from the M5 southwards, but I think quoting satnavs as a reason is putting the cart before the horse.
tigerroar
30 May 2010
Gloucester
How long ago did the airport actually become a thing there? I do remember the Filton suggestion and the noise impact over Frampton Cotterell.
ashkeba
13 May 2019
Or you ease the intended main route and restrict (or in extreme close) the small lanes until the software stops using them. Building more roads encourages more driving when we need to encourage more train use.
Lucan
21 Feb 2018
Wales
Bristol Airport is in a terrible position regarding transport links..... (Filton was rejected because they went and built all that new housing in north Bristol along with the Cribb’s Causeway retailing area just north of the airfield).
The irony is that much of that housing contains Filton workers making and maintaining aircraft. But they objected to an airport. As for Cribbs Causeway, since when were shoppers deterred by over-flying aircraft? As both Filton and Cribbs are blots on the landscape, being together sounds perfect to me.
Filton Airfield is situated right by one of the corners of the London-Bristol Birrminham transport triangle of both motorways and railways. A railway runs right alongside and an M5 junction is less than a mile away. The railway is currently freight only to Avonmouth, but with a relatively easy re-doubling of the Temple Meads-Clifton-Avonmouth branch, some London (or Birmingham)-Bristol Parkway-Bristol TM trains could be routed through it. Again, a perfect location for a Bristol Airport. Lullsgate is nonsense.
I started threads on that in both the "Infrastructure" and "Buses & Coaches" sub-forums. The scheme is barmy, and I cannot imaging central government will accept it in its present form. I must admit I had not thought of the main route from Bristol to its airport also being severed, in addition to the the main route from North and North-West Bristol to South Bristol generally, and complete loss of access to Temple Meads Station.
ashkeba
13 May 2019
Why would Bristol traffic be driving on a road out to its west to reach an airport to the south? Also, any diesel restrictions in Bristol will affect resident drivers more than airport trips so the main nuisance will be for through drivers from the M5.
I think I read that the A371 bypass the single track centre of Banwell is now to go ahead. If a junction with M5 is provided that looks like an obvaious M5-Airport road link better than any current one, no?
I also read that current thinking is for light rail not a new NRbranch. Can that cope with steeper gradients?
Lucan
21 Feb 2018
Wales
The airport is south-west of Bristol, not south. To reach it either from Bristol or the M5 J18 (currenly best junction if you are coming from north or east) you would leave the city area via either the A38 or the A370. If you look at the map of these zones https://www.cleanairforbristol.org you can see that the Bristol ends of both roads fall inside the diesel car ban. Only people coming from south Bristol to the airport would avoid these points without a lengthy diversion.
The geography of Bristol is such that it is hemmed in on the west by the River Avon and its gorge. The Portway, which runs through the gorge, is the only through route from north to south Bristol that is west of the city centre, and this ban severs it. There are almost zero houses alongside the ban stretch BTW - it's in the gorge. The next available north-south route for diesel cars to the west will be down the M5 J21 to Weston-s-Mare and then back up north-eastwards on the A371 etc; or turn earlier at J19 or J20 into a maze of back lanes as Envoy described.
Indeed. I am not interested in Airport trips myself and had not even thought about the Airport problem until Envoy raised it. I live in South East Wales and frequently make trips to Bristol, and Bedminster (south Bristol) is a good place for things like car tyres, and building materials. I am shortly going to buy a 3-piece suite from Parkes, a large furniture shop there. But I will not be going to Bedminster again if this ban is implemented because I would need to go either via W-s-M or round the east via the Bath Road area (which is a semi- permanent traffic jam), and both options are utterly unreasonable for me. The same problem will apply to anyone in north Bristol if they have a diesel car.
It's not all bad. Bristol Council are considering a scrappage scheme for diesel car owners to help you buy a bicycle instead.
ashkeba
13 May 2019
Or presumably one could buy a cleaner car? Or in Bristol join a car club.
ashkeba
13 May 2019
Including all the visitors to the 3 Hospitals in the "banned" area, who could be anywhere from up to 100 miles away?
Hospitals are usually served by park and rides and don't have enough parking for all those who try to drive to them. Hopefully this might also mean better bus services from nearby train station. I would hope that hospital users welcome a pollution reduction measure that should see a reduction in people being made ill by pollution and also money able to be transferred from expensive city centre car park subsidy to patient care!
option
1 Aug 2017
ehh?
The majority of Filton Aerodrome was always north of the line, & went up to the B4057. The rail line is also in a cutting.
Just off the end of 21, at the north-eastern corner of the site, is the junction of the B4057 & A38, where they also cross the main Bristol-Cardiff line.
https://www.ukairfieldguide.net/images/imgexec-3091.jpg
ashkeba
13 May 2019
ehh?
Yes, "the majority of Filton Aerodrome was always north of the line" but that means the rail way did indeed go through the site as @edwin_m said.
It is not all in a cutting. Satellite images show a level crossing hidden by the 03 on your image, between the runways and the southern hangars.
Filton airfield required Charlton village and a bit of Catbrain demolished. Why would anyone have also demolished maybe half of Patchway and a country estate to expand it further to accommodate Bristol-Whitchurch's airport traffic as well as development use, when there was an underused airfield at Lulsgate and they did not know a motorway would pass so close west of Filton 12 years later?
Lucan
21 Feb 2018
Wales
Not sure what you mean by "expand it further". Filton is or was the longest runway in the UK, and until relatively recently there was a vast empty area to the North/North-West where the Cribbs Causeway retail park and housing estates are now (they are still building them). Before the M5 was built, there would even have been room for another runway, North-West to South-East, almost as long as the East to West one. There would have been no need to "demolish maybe half of Patchway" at the time, it is a mile away - in fact an entire new housing area (Charlton Hayes) has since sprung up between the airfield and Patchway.
I'm not sure why the Avonmouth freight line along the south side of the airfield is meant to be a negative point. Even if a new North-West to South-East runway were added it could utilise the existing land bridge at Charlton Common. In fact an airport station along there would be perfectly situated.
The ideal location of Filton as the airport for Bristol pre-dates motorway building. Railways had greater strategic importance then, and Filton is at one of the corners of the London-Bristol-Birmingham railway triangle, just as now it is also at the corner of the motorway triangle. Even back then, only someone blindfolded could have thought that Lulsgate was a good place for the airport. Lulsgate was probably accepted as Bristol's airport because at the time no-one imagined air being used for mass transport; it was assumed that the clientele would be a a few dozen VIPs and millionaires arriving chauffeur driven from a country estate.
Tomos y Tanc
1 Jul 2019
We have to start from where we are.
Filton might well have been a better choice for Bristol's airport, but it wasn't chosen. Similarly, in retrospect, it would probably have been better to divert the river Rhymney and expand the original Cardiff Airport at Wentloog rather than ship everything out to Rhoose. We have to live with those decisions.
The questions now are how do we improve public transport connectivity to both airports and increase air services from both so passengers from both sides of the channel can avoid the awful schlep to the various London airports.
Bristol seems have cornered the bulk of the short haul and budget airline market while Cardiff is making a decent stab at long haul. Personally, I'd give my eye teeth for direct services from either airport to destinations in the Americas and Asia. Naturally, there is competition between the two airports but, in terms of the economies of both south Wales and the West, the emphasis should be on ensuring international connectivity, rather than which of the two airports airlines chose to use.
