At the trade rate, there isn't much difference now, but it is still cheaper when you are bulk buyingDiesel was until recently cheaper then petrol
What's torque I've heard that word before?
Yeah I've always wondered what the difference is (I don't drive) because both come from oil? The only difference is what happens to it once it enters the exhaust system>?
Diesel fuel is a lot safer as well.
If you want simple and light, go for a gas turbine. The simplest have one moving part, the turboshaft itself.
Wondering why these trains can't be petrol powered is diesal preferred?
According to family legend, my grandfather (the one who was a test pilot) sometimes used to fill his car up with aviation-grade petrol. It ran beautifully.
If you want simple and light, go for a gas turbine. The simplest have one moving part, the turboshaft itself. Theoretically, they can run on diesel or petrol, but normally on a particular grade of kerosene. Thing is, they don't like spooling up and slowing down all the time, so they do not really work in something that runs at varied speeds.
Wikipedia said:"Each turboengine was equipped with a 3500 litre diesel tank for use on long routes, with a consumption of 430 litres per hour for traction and 150 litres per hour for passenger comfort."
In WW2 the Germans used Petrol powered tanks rather than diesel like everyone else, you can look up the problems that caused with underpowered engines that wouldnt work in cold weather or in wet environments.
I can believe that - an aviation expert told me last year that the premium unleaded petrol currently available is not very much different from the old JP-4 aviation fuel.
The British Centurian tank used a RR Merlin petrol engine
The M4 Sherman used a petrol engine as well as I recall, and it developed a reputation for catching fire very easily.
A few American tanks got the nickname "Ronsons" because they were "guaranteed to light, every time". The Germans, rather more bluntly, called them "Tommy Cookers".
