Elizabeth Line - total loss of signalling 26/11
ChristopherJ
Repeatedly returning banned member
8 Aug 2005
London, UK
I'm surprised no one has reported this yet. One of the busiest rail lines in the UK has been closed all afternoon (and still is) and not a dicky bird. If it isn't about TPE cancellations or Northern penalty fares, you seemingly aren't interested.
The Elizabeth Line has had a massive single point failure of the Siemens CBTC signalling system - unable to get train detection in the whole Crossrail Core from Paddington to Abbey Wood. Still closed approaching 15:00.
According to a source within TfL "it's one of the worst signalling failures we've ever seen".
I haven't studied the Crossrail CBTC system, but I'm lead to believe it's structure is radio beacon rather than track circuit/axle counter based?
ijmad
7 Jan 2016
I haven't studied the Crossrail CBTC system, but I'm lead to believe it's structure is radio beacon rather than track circuit/axle counter based?I
I believe Trainguard MT uses a combination of onboard movement sensors on the trains (wheel rotation counters, inertia sensors, etc.) combined with occasional track balises for recalibration (but not a constant series of them like on ETCS), it then sends positioning information back to the control computers via radio.
No idea which of these parts have failed today and whether it's a hardware or software problem.
Sounds pretty catastrophic whatever has happened.
Horizon22
Jobs & Careers
8 Sep 2019
There were some issues yesterday with the system but it only partially failed where timetable data wasn’t properly feeding the CIS.
This morning the system totally failed and lost comms with trains and various things like interlocking so was unsafe to run. Was reset on multiple occasions with no success. It sounds like the exact nature of the fault has been hard to ascertain. Probably be closed for the rest of the day with a reduced service from Paddington out on GWML and Liverpool Street out on GEML.
I think TfL are right to call it one of the worst signalling failures they’ve ever seen!
ChristopherJ
8 Aug 2005
London, UK
Approaching 17:00 peak and not a single Elizabeth Line train in the whole COS according to Traksy.
TfL are radio silent on the matter (just like their signals), not a mention or apology of the service suspension on Social Media.
This evening is going to be unimaginable. Glad I'm in an Airbnb until tomorrow!
bluegoblin7
10 May 2011
JB/JP/JW
TfL haven't used social media to provide service updates for some years.
Not sure how much clearer the suspension can be, mind.
zebedee104
19 Jun 2016
That's not even correct information either, is it? There's no service between Paddington and Abbey Wood AND Paddington and Stratford (in the core). Well aware Shenfield trains are going from Liverpool Street mainline.
ChristopherJ
8 Aug 2005
London, UK
Given this shambles has been ongoing since almost 23:00 yesterday, now affecting two peak periods, I suspect it won't be long until Sadiq posts a grovelling apology on X, similar to the Ladbroke Grove incident.
According to RTT, some of the final late night Elizabeth trains were an hour late through the COS yesterday, then the service shut down completely from 05:00 this morning.
Here's a 24 hour snapshot from Tottenham Court Road.
THC
21 Sep 2009
Stuck on the GEML
I travel from Chelmsford to Ealing for work a couple of times a week and had the presence of mind to jump on the Central line this morning when changing at Stratford. Just at Paddington on the way back now, about to jump on the H&C. Cost me an extra half an hour this morning and probably double that on the way home.
THC
Horizon22
Jobs & Careers
8 Sep 2019
Very technically it would be "Paddington to Abbey Wood and Stratford". But because of the quirk of their being an additional stop between Stratford and Liverpool Street (Whitechapel) in normal operation but not when running from mainline, this confuses the TfL disruption map.
Some extra trains running from Stratford and Ealing Broadway this evening rush hour to help increase capacity a little.
That was a separate trespass incident around Ladbroke Grove and affected GWR too.
SECR263
6 Jun 2018
Travelled in on Thameslink and Southern caught a Jubilee in morning, now on DLR home. No onboard announcement on trains or Station Liz line is kaput. Not good
Horizon22
Jobs & Careers
8 Sep 2019
This is always a challenge - most modern PIS on-board trains is automatic with interchange info and another TOC getting a message to every driver about another TOC's disruption is hard enough, let alone that message getting broadcast. It definitely should be better though, just harder to achieve in practice.
BahrainLad
3 Aug 2015
Just came through Liverpool Street tube and it’s a complete mess, huge queues to get down to the Central line platforms.
I know what you mean, but EL is still operating west of Paddington and east of Liverpool St/Stratford.
So not completely kaput. ;)
Horizon22
Jobs & Careers
8 Sep 2019
In some ways it is amazing to think that just less than 3 years ago the central section of the line didn't even exist. Obviously there was still the Covid passenger reduction then.
Malaxa
9 Mar 2022
Onboard TfL network messaging on EL trains this pm showed "Elizabeth Line - minor delays" lol!
Horizon22
Jobs & Careers
8 Sep 2019
There were Minor Delays Liverpool St - Shenfield outside of the peak.
THC
21 Sep 2009
Stuck on the GEML
The alternative passenger flows and footfall seen today (Paddington, Ealing Broadway, Liverpool Street and Stratford) make it obvious how much traffic the Elizabeth line now absorbs in regular service.
THC
GFE
6 Jun 2024
HA4
Rather unfortunate that the Central line is also running on a reduced number of trains
Sleepy
15 Feb 2009
East Anglia
Travelled on central line yesterday for 1st time in years - quite shocked how jaded stations and trains look.
Horizon22
Jobs & Careers
8 Sep 2019
ECS tests happening soon. If everything works, a shuttle (Paddington - Abbey Wood) might be implemented for the last few hours of service.
ScotGG
3 Apr 2013
South Eastern's Metro services were also cut after the Lizzie line begun. A tad cosy today
