ELR Station and Junction Mileages
Legolash2o
27 Sep 2018
Is there a source within Network Rail that has all the ELRs with miles/chains for all the stations and junctions with the ELR they connect to? In a digital way (CSV, Excel, SQL, etc).
I know there are things like the Railway Codes website but it's not an official source and don't know what the source data is.
pdeaves
14 Sep 2014
Gateway to the South West
For current routes, you want the Sectional Appendix [to the Working Timetable - to give the full name]. That is the main source for Railway Codes, too.
Bristol
The official source data is indeed the Sectional Appendix. All other data is supposed to be taken from it. Each table will show the routes at a junction with the Line Of Route Code, and then if you go to that LOR table it'll show the ELR in the top corner. It should show all mileages, with mileages on the connecting lines in brackets.
Bear in mind that ELRs are used primarily by the Engineering departments, whereas planning departments tend to use the LOR codes instead.
Elecman
31 Dec 2013
Lancashire
The quail map books also have that data
Legolash2o
27 Sep 2018
Thanks for the reply. Sorry, I didn't specify in a digital file(s) or database. I've updated the first post to reflect that.
