EMR Driver/Guard Diagrams out of Norwich
Dirty_Mac
2 May 2024
Edinburgh
Thinking about writing a bit of fiction and fell into this rabbit hole. How are EMR personnel operating out of Norwich diagrammed? I know they probably change at Nottingham, but what then? Norwich to Nottingham is 2.5 hours, so not enough time to do two round trips, so what do they do before heading back?
westcoaster
4 Dec 2006
DTOS A or B
Also factor in the early shift will prep the train (in platforms or in the depot), late shifts will take them to be cleaned, fueled, toilets serviced and parking up for the night.
Shifts could be Norwich to Nottingham and back once or twice. I belive they used to go to Mansfield as well.
Check the routes signed section on the careers page here.
Also says they go Nottingham to Leicester so they might do that in the middle.
Tomnick
10 Jun 2005
They have a couple of jobs with a round trip to Leicester in the middle. As above, there's preps on the early jobs and shed/ferry work on one of the late turns too, although they have a dedicated shunt turn too now because of the uncertainty over timings when waiting for fuel on someone else's depot!
westcoaster
4 Dec 2006
DTOS A or B
I'm also guessing they may have refreshers over the route between Peterborough and Leicester.
Might go Norwich to Nottingham to Leicester refresh to Peterborough and pass back to Norwich or reverse.
bunnahabhain
8 Jun 2005
Monday to Fridays the Guards have 4 out and back diagrams, and 2 with a Leicester attached. Weekends they just do out and back turns with extended PNBs at Nottingham.
Drivers are the same, but don't pair up with the Guards for the Leicester, and aren't always paired with the Norwich guards in one direction. They also have an additional shed and ferry turn at night.
There are also route refresh diagrams for Peterborough to Leicester.
There are plans for Guards to sign Derby to increase their diagramming efficiency as its a relatively short additional route which can be done in less than an hour.
More interestingly, there were plans for Guards to sign Sheffield via Radford, Alfreton and Dronfield, they would work the 1256 Norwich to Sheffield PNB, then work the 1745 Sheffield to Norwich. This was when the 1547 (as was) Nottingham to Liverpool had additional calls at Irlam, Birchwood and Hunts Cross and so bust the break time at Liverpool. Covid kicked off, as did the threat of TPE taking the route beyond Nottingham, so it never happened, but it came very close.
They used to work other services so the depot "inefficiency" was caused somewhat by the split of Central Trains, as well as Covid which killed off their Worksop route knowledge which was then compounded by the timetable change which extended the round trip time on that route.
