When fare-checking a routeing-point group, the human-facing routeing guide(http://data.atoc.org/routeing-guide) is silent on how you choose a member of the group for the fares check.
The on-line routeing point calculator (http://data.atoc.org/rp_calc) seems to implement an (undocumented) rule that excludes routeing point members which can only be reached by passing through another member.
For example, when testing Brighton Group as routeing point for origin Shoreham-by-Sea, you compare Hove fares and not Brighton fares.
I'm not sure that this rule is well-defined in all cases (e.g for Lydney to Coleshill Parkway rp_calc rejects Birmingham Snow Hill as impossible to reach without passing through another group member even though that could easily be the first Birmingham Group member arrived at. ) It's also tricky to apply the rule without implicit knowledge of the local railway geography at a level of detail not given in the routeing guide itself.
I understand the electronic routeing guide simply defines a 'main' routeing point group member and all fare-checks on groups are done using that station.
Is there a publically avaiable list of these main stations for each routeing point group? (Some are easy to guess - others aren't.)
