Forget e-mails there is no substitute for a real letter, I get most disappointed on days I receive no post. :cry: (excluding junk mail).
Did you have exposure to mail trains as they would still have been running when you started ?
The only exposure I had was in sorting the mail into the fittings that were, sometimes, labelled with the name of a TPO, and making up bags of mail to be sent to that TPO.
I had the option to apply to work on the South Wales TPO, but in those days I enjoyed socialising too much to work permanent nights and spent time away from home, which was necessary on that particular run.
IIRC, you booked on at 1730 on a Monday and travelled passenger up to paddington, to work the train back to Swansea. You then worked the service up to London (booking on around 2110) on Tuesday and Thursday, working back on Wednesday and Friday.
I decided it wasn't for me! Most of those who worked the TPO were older gentlemen, but it was a sought after position for some because of the additional money in the form of Night Duty Allowance, and the subsisdence payments for being away from home. Once they got on the trains, very few came back into the office!
Shetland mail goes through Aberdeen. AB and ZT postcodes are mixed in together until it reaches Aberdeen Mail Centre. There might be a chartered cargo flight from Aberdeen to Sumburgh, else it will go in the cargo hold of a passenger flight.
Royal Mail used to use RAF Kinloss for Highlands and Orkney Mail, then truck it to either Inverness Mail Centre for further sorting to local DO's or Inverness Airport onto passenger flights to Kirkwall. However, around the same time as Kinloss closed, Inverness Mail Centre was downscaled to a Delivery Office and Aberdeen now handles most Inverness/Highland mail. Glasgow Mail Centre handles the Inner Hebrides mail (Islay, Jura, Gigha, Mull, Coll, Tiree (PA postcodes)) Gigha and Mull will have all mail carried by road and ferry, second class mail will also go by ferry to the other islands. All Camlac ferries have a padlocked locker reserved for carrying mail. I assume Aberdeen now handles the Outer Hebrides (HS postcodes).
In Scotland there are only 4 main hubs. Almost everything by road goes into the Scottish Distribution Centre at Wishaw then to, Edinburgh, Glasgow and Aberdeen Mail Centre's, then to local DO's
All British Airways aircraft carry a small Royal Mail badge somewhere on the fuselage.
I knew I was a bit out of date! Thanks for the update!
There's a massive Amazon warehouse near me at Dunfermline, all their Yodel deliveries go to either Manchester or Droitwich for sort before heading out to there local delivery centres. So I order something from amazon, it might go from Dunfermline, all the way down the M74/M6 to Droitwich, back up to Edinburgh or Perth, then out for delivery...
I believe the Royal Mail has dedicated Amazon facilities? Or did I dream it? I suspect that the Manchester and Droitwich hubs are dedicated, do you know if that is correct?
There is an Amazon warehouse in Swansea, Apparently it is not a good place to work...
