General bathroom cleaning tip help
heart-of-wessex
11 Jun 2005
Trowbridge
Hello all,
I'm no master at cleaning so I hope someone can help! Has anyone had to scrub the grime off the bottom of a toilet pan before, where the water lies? It doesn't seem to be a simple case of leave some Harpic down there and then scrub off with a scourer pad off the back of a sponge, it won't come off no matter how many times I scrub over it with elbow grease!
Is there any particular recommended product that should at least ease off the grime so there's a chance it'll come off?
IanXC
Emeritus Moderator
18 Dec 2009
The strongest bleach I've ever come across is Domestos Grot Buster, but I've not used it in the situation you describe I'm afraid.
Mr Spock
14 Jan 2008
Its possibly limescale deposits (from hard water), not sure if descaler will move it otherwise use an old knife or similar to gently chip it free. Then clean on a regular basis to stop further buildup.
Wyvern
27 Oct 2009
I use about a cup full of malt vinegar and let it stand overnight, then brush it clear in the morning. Cheaper than Harpic etc. and better for the environment. Smells like a pub though.
Peter Mugridge
8 Apr 2010
Epsom
Spirit of salts ( hydrochloric acid ) is very effective, but be careful - it's a very dangerous substance.
Don't think we're allowed to use it in drainage systems these days are we?
heart-of-wessex
11 Jun 2005
Trowbridge
Could well be actually, Trowbridge is in a hard water area. Will see if something like that works, or the vinegar tip, will report if any of it works
theboywho
6 Dec 2010
Newcastle-upon-Tyne
If you get no luck, pump the water out and let a couple of bottles of cheap cola sit in there for a while.
TESCO used to do a rather poor bottle at 15p a few years ago. This ought to eat away enough for a good scrub.
185
29 Aug 2010
I learnt from the experts.... breaching all COSHH and Health and Safety, the carriage cleaners used to sneakily use Dettol 'Mould & Mildew' bleach (green spray bottle). 5 minutes sprayed on the pan or the standing water and anything goes. Ventilate very well, it's the strongest bleach I've ever seen. £2.50ish at Asda.
313103
13 May 2006
Try using a 1 litre bottle of coke, open it and allow the coke to go flat and then pour into toilet. This is a trick my wife did when we first moved into the place we currently live.
Crossover
4 Jun 2009
I seem to recall seeing something on TV about removing limescale from top ends - basically was white vinegar in a bag, left for a while.
Funny you should say that. When I was in halls at uni, I heard a story from the cleaners that although the uni provided cleaning products, to comply with the various H&S regs, they were all c**p (bleach I think being the main thing mentioned)
Of course, the cleaners just brought stuff themselves that actually worked!
DarloRich
Fenny Stratford
Hello all,
firstly we need to work out what it is. Is it:
a) Limescale
b) "residue"
c) Mold
what colour is it? Has it been there long?
If it is limescale get strong bleach, cilit bang remover is good or a specialist limescale remover. These will stink so you should make sure you ventilate the area. Just follow the instructions on the bottle and away you go
If it is residue get a strong bleach, let it soak in for a while and get a toilet brush and scrub.
The old coke trick might work depending on how ingrained the problem is. Poor in a bottle, even fizzy coke will do, and leave overnight for harsh staining. It is the phosphoric acid in the Coke that breaks down the lime scale (apparently)
If it is mold get a mold and mildew remover and poor it in. This is not very sensible but will do the job! For god sake dont ingest any!
Bevan Price
22 Apr 2010
A bit off topic, but if you use bleach (sodium hypochlorite), be careful to keep it away from any chrome-plated taps, sink or bath plug-holes, etc. - these are easily damaged by bleach....
Welshman
11 Mar 2010
What a wonderful site this is. :D
All the latest opinion re HS2 to how to clean your toilet.
What more do you need?
youngboy
28 Jan 2013
Whilst giving tips out, anyone with an old cast iron bath with a line round or 'yellowy'. Brown Sauce all over overnight then wash off day after, works a treat !!
