Hellfire! Kickdown!
GusB
Elginshire
I've just watched a YouTube video that refers to "full kickdown". I often wonder if the term "kickdown" is fully understood.
My understanding of "kick-down" is that it is the forcing of an automatic gearbox to down-shift by pressing the throttle pedal beyond a certain point in order to make the engine run a bit faster; it could be to facilitate overtaking, or to aid hill-climbing.
In the video I watched, the "kick-down" described was nothing more than the driver exiting a junction and giving it a bit more welly so that the gearbox didn't change up as quickly as it would have done normally. The gearbox in this case is up-shifting all the way and therefore there is no "kick-down".
Discuss :)
31 Dec 2021
Kickdown switches have pretty much became a thing of the past and for the most part modern gearbox software can be configured to hold gears long enough to provide good acceleration, even if most operators now focus solely on efficiency.
richw
10 Jun 2010
Liskeard
Most modern buses don’t have kickdown available. Last buses I drove that had it were 2002 plate Tridents. Our new stuff doesn’t have it installed for fuel consumption, and quite frankly it isn’t needed.
15 Sep 2019
Back in Geordieland!
On some old buses you could feel the kick down switch at the end of the throttle travel, keeping it pressed would hold the gear a bit longer.
All the buses I use now are full automatic, I would much prefer driving a semi automatic.
Do they still make semi autos?
CBlue
30 Mar 2020
East Angular
While I don't think the Hydracyclic / Pneumocyclic gearboxes used by Leyland back in the day continued past the mid 1980s along with the SCG items fitted to Bristols, some modern automated gearboxes (like the Volvo i-shift 12 speed - effectively a computer-controlled electronically actuated manual gearbox) do have a semi-auto mode where you can control gearshifts. I think the ZF as-tronic fitted to some DAF and Mercedes coaches allowed similar operation modes.
stuart81
9 Oct 2015
Ipswich
It's like the term "thrash" that people use to describe pulling away from a junction briskly than normal, drives me bonkers
richw
10 Jun 2010
Liskeard
Adds Unnecessary additional stress on the engine. I Wouldn’t drive my own car like that so I don’t drive buses like that neither.
The thrash seeking enthusiasts get disappointed with me!
Richard Scott
International Transport
Railtours & Preservation
13 Dec 2018
Not really, diesel engines actually like being thrashed and are designed to cope with it.
31 Dec 2021
Volvo B7TLs either with Voith or ZF both rev out and have lasted some 15-20 years, seemingly with no problem.
The kickdown switches have simply been removed to scrounge efficiency.
They can still be fitted if requested.
notadriver
1 Oct 2010
One of the main differences between coaches and buses is the former are tuned for performance and have a kickdown and/or manual override available
*except national express / megabus / Oxford tube.
gmaguire
29 Dec 2021
So they're using the term "kickdown" to describe the use of the kickdown switch, even if there is no downshifting prompted by said switch.
Off topic, but something I like about Hong Kong bus enthusiasts compared to ours, is that more often than not they record their videos from the front of the bus, instead of the back. There's much more to take in at the front of the bus. I like watching the bus turn and the driver turning the steering wheel. The engine noise at the back gets old after a while.
But what is "full kickdown" ?
route101
16 May 2010
Yes, I noticed a lot of bus enthusiasts will sit downstairs at the back all because of the engine noise. There one person on Youtube that would record a full route yet his camera was pointing to a window pillar, rather than the view out the window.
I recall the kickdown on the tridents, did not realise modern buses don't use it now.
GusB
Elginshire
Booooo-ring!
In all seriousness, that makes you a good driver and you should be applauded. It's all about fuel economy and a smooth drive for the passengers.
Having said that, I do miss the days where drivers had right feet that were much heavier than their left feet. What speed limit? :)
fgwrich
15 Apr 2009
Hampshire
On a slightly different tangent as you've mentioned Voith, who I've always been a fan of - I rather miss our X-VAP batch of Super Pointer Darts at Stagecoach South, whose deep throated roar and Voith retarders could be heard screaming from some distance away! Whether or not they had a kick down I don't know, but they did sound pretty meaty.
Strathclyder
12 Jun 2013
Clydebank
Sounds much like the later Super Pointer Darts Lothian, Cardiff etc, bought. A Voith box/retarder and a larger Cummins lump made them sound really rather different to other Darts. Whether or not they had kickdown I don't know, but as you say, it made them sound really rather meaty indeed. Always was a treat to see one of the ex-Lothian ones with a new owner; Newmains-based JMB Travel was a enthusiastic purchaser (as below, images are my own).
Cowley
15 Apr 2016
Devon
Booooo-ring!
There’s nothing like an Italian Tune-Up. :lol:
Mikw
20 Apr 2022
Leicester
What about Streetlites? I'm not fan of them. I've noticed that sometimes they lurch violently into a lower gear and the passengers get thrown around, and gasp.
Lewlew
15 Oct 2019
That's the retarders. No matter how lightly you press the brake pedal everyone gets thrown forward. Horrible buses to drive.
pdq
7 Oct 2010
Arriva Yorkshire have some tiny ADL Enviro 200 buses (eg YY14LHB) with what sounds like an automated manual gearbox, in that up changes really feel like a manual change using a clutch. They seem poorly suited for hills because so much momentum is lost on the very slow shift between 1st and 2nd, and it feels like the space between the gearing is too great. They just keep shifting up and down on hills, so I guess there is no way to hold the lower gear.
Mikw
20 Apr 2022
Leicester
Horrid to be a passenger on as well. They replaced Optare Solos on our route, not a good replacement.
MacT
6 Jul 2021
Dorset
Sounds like the ZF AS-Tronic which was more common on E200s, I believe it was designed for trucks initially. It appears to have a manual override on the gear selector with buttons to allow the driver to drive it manual,y, changing gear via the relevant up or down button, however I assume many companies either don’t train drivers on such systems, or prevent them from accessing such features.
31 Dec 2021
That’s exactly what they do.
9 Aug 2017
Same with some of the Pulsars at Arriva Castleford. Really violent going from 2nd to 3rd (if I remember correctly) sometimes. I'm no mechanic, but it must be something to do with the transmission and engine not getting along too well.
31 Dec 2021
The following explanation is extensive but it should reassure you for those who don’t know of the way modern engines & gearboxes are controlled and how they work together.
The physical mechanics of modern auto transmissions you’ll find in buses from Voith, ZF or Allison isn’t the problem, it’s almost always a sensor, connector, cable or controller that’s faulty if they don’t sync well, not always but mostly.
different gearboxes can have unusual side effects given the engines they are attached to as well, all engines of course have different torque and power graphs and also the weight of the vehicle can have an impact on drivability as well.
naturally as transmissions age they can become alittle lumpier in there shifting but just like engines and even differentials, gearboxes need fluid changes as well to keep them internally healthy, additionally most torque converter autos fitted to buses have integrated retarders, further adding to there complexity, the need for them to be calibrated well with the engine is important to say the least.
Not on all but on most modern buses & coaches you’ll find a TCM & ECM, a “Transmission Control Module” & “Engine Control Module”.
Both these naturally have to communicate with each other and for the most part they should work fine together, done properly, a well-known exception to this is the Wright StreetLite.
It did improve when Wrights introduced the Daimler engined version, however, they still aren’t great, I simply see this problem as a mismatch between the engine and gearbox software not the actual physical mechanicals, for the most part.
After being able to speak to engineers over the years at depots and engineers from various bus builders, it’s because they have been calibrated for all out efficiency and to ensure such vehicles as the StreetLite can gain LECB certification and savings to there lowest costs possible.
As I recall a Voith engineer say to me, when you try and go for all out efficiency a side affect of this is often the gearbox throwing up and down its cogs trying to stay within a very narrow rev band for efficiency and then seemingly becoming Un-talkative with the ECM, as though one or the other has became confused, most often the gearbox.
Any drivers who’ve driven a Cummins/Voith bus, streetlite or otherwise, you can be slowly manoeuvring, the gearbox has made a gear change so you then go to put the foot down again to progress, only for the engine to rev flare whilst you get breathless acceleration then suddenly it’s as though the gearbox has “thumped” into the gear it should have already chosen, Voith units attached to Cummins lumps are notable for it.
Back to Kickdowns, acceleration & shift points, kickdowns can be fitted if you request that, we know that.
Engine Power & Torque is obviously an important part of the way a vehicle can accelerate as is the way in which the gearbox will change gear at a specific RPM.
abit more about the ECM & TCM, the engines “push” is controlled by the ECM which can be increased or decreased, Cummins refers to this as VAM, “vehicle acceleration management”.
Read here:
Even though the engine for example could be rated at say 250hp & 1000nm of peak torque, VAM virtually restricts how hard the engine will push, this is the “exact” reason many newer buses are sluggish, it’s not because these modern engines are under powered, far from it actually.
If the VAM is set appropriately and often it is not, if it were then there is very little need for a forced kickdown switch to be fitted.
The TCM, this is where you‘ll find software to many known as, TopoDyn(ZF), SensoTop(Voith) or FuelSense(Allison).
Essentially this software controls the shift points of the gearbox either dynamically and/or partly dependant on the gradient of the road, older transmissions like the ZF Ecomat or older Voith models had “set” shift points dependant on the “mode” the TCM had, Eco, Normal or Power for example.
It’s obvious what the software does here, it allows each operator to tailor there choice.
Between the TCM & ECM, the variables can be significant between different buses and there operators.
First Glasgows fleet alone is notorious in the way there vehicles perform, there 65-plate E400 models being particular poor on acceleration, pulling away and on the move, put that in contrast to anything diesel that’s been branded for the 38.
Unstoppable
11 May 2015
Megabus vehicles speaking from a Panorama and Astromega perspective have kickdown and can also be driven in manual. The Panoramas also have a performance button
