Early 1980s, Bristol had some electronic blinds fitted to the Y reg batch of Olympians and trialled them on a VR before that.When we're the first electronic blinds (nor roller) introduced on buses and coaches in the UK,?
Transign. They weren't the only operator to do it either. Two VRs fitted - EWS753W and EWS754W, then all of the Leyland Olympians in the JHU---X, LWS---Y, NTC---Y, A---SAE, A---THW batches.Early 1980s, Bristol had some electronic blinds fitted to the Y reg batch of Olympians and trialled them on a VR before that.
Indeed, that is the same Transign display noted above, as pictured here on one of the aforementioned Olympians.Yorkshire Tractions first olympians, X registered had a strange electronic display where each digit of the display was formed of a block of rollers which displayed an element of a letter according to how much it was rotated, any letter could be formed by varying the rotation of the rollers to display different degrees of black or white. Very strange things and soon replaced by standard blinds.
Didn't that one have a previous incarnation of digital display, I seem to remember it being a liquid crystal unit as in a big version of the early digital watchesNottingham 666 (ARC 666T) had an LED number display when new in 1979. Later replaced by roller blinds.
Lots of National Bus Company subsidiaries had Transign blinds. Southdown retrofitted two VRs with Transign equipment https://www.flickr.com/photos/7964319@N03/48026388802/in/photolist-iNupAJ-2gaVNbf/ flickr photo courtesy of kwk33f which was done in Portslade works. The off centre aperture was to accommodate the periscope! Whilst PUF586R survives, it has a later flipdot that it received when with Brighton and Hove.Transign. They weren't the only operator to do it either. Two VRs fitted - EWS753W and EWS754W, then all of the Leyland Olympians in the JHU---X, LWS---Y, NTC---Y, A---SAE, A---THW batches.
Here is an example of a contemporary United Counties Olympian, and a retro fitted VR.
United Counties ARP608X
Leyland Olympian / ECW ARP 607X of United Counties is seen heading down Midland Road in the early 1980's - the uncomfortably abbreviated Transign destination should be noted. Nowadays the building behind is a Tesco Metro whilst to the right is The Pilgrims Progress Wetherspoons, frequented by...www.flickr.com
United Counties Bristol VR/ECW (924-ONH924V) Bletchley, Bus Station (3/1983)
United Counties Omnibus Company Limited Bristol VR-SL3/ECW 924-ONH924V New to UCOC as 924 (5/80) Fitted with Transign Electronic Equipment (11/80) To Milton Keynes Citybus (1/1/86 as 3924) Bletchley, Bus Station 3/1983 (Roger Warwick Collection)www.flickr.com
Midland Red had a batch of Nationals where the route number was fitted to the triangular panel to the side of the normal destination apparture.
Many, if not all, of these vehicles later got conventional blinds.
Blazefield went with a digital number but roller blind for the destination
File:LANCASHIRE UNITED 1080 PO51 MTF (3619693913).jpg - Wikimedia Commons
commons.wikimedia.org
First experimented with these displays in a batch of Scanias (destined for Leicester) that spent a short spell on loan to Eastern Counties at Ipswich. Does anyone know the official name for them?Reading Bus had something similar in the late 90s - the route number was the same type of display as Network SouthEast clocks (and was repeated on the rear of the bus as well)
Link to photograph on the showbus.co.uk site of Reading Buses Excel 908 (P908EGM)
Contemporary pictures (available via your search engine of choice) show greeny yellow (seven segment) figures like a calculator, or as you say, digital watch. I thought that was an LED rather than LCD, but am happy to be corrected.Didn't that one have a previous incarnation of digital display, I seem to remember it being a liquid crystal unit as in a big version of the early digital watches
If I'm right. they were not too reliable at first, as one continually showed PIE HEAD instead of PIER HEAD!Merseyside PTE [MPTE] introduced electronic blinds on buses from 1982, first batch to get them were a batch of full height Olympians from 0030 onwards, yes that was the fleet number.
The first electronic blinds were one piece blinds, however they were criticised because you could hardly read them, so MPTE revised the electronic blinds & introduced a bigger electronic number blind, above the electronic destination blind.
In Merseyside the electronic blinds were fitted to deckers, i can't remember any electronic blinds fitted on new single deck buses in the Merseyside region until 20 years ago
LO1 was a notable bus - one of the Olympian prototypes and also fitted with the first Alexander R-type body. A shame that it was lost in the Larkfield fire.GGPTE Leyland Olympian/Alexander LO1 (VGB364W) had an electronic screen but it was so unreliable it was replaced by a conventional unit by 1985.
