I didn’t know they had that!! Rolling stock you didn’t know that company operated.
generalnerd
20 Jan 2025
Hull
What rolling stock would you consider as interesting or unique/you didn’t realise that company owned/operated the rolling stock?
For example, the southwest trains class 73, used for rescue operations:
trainmania100
8 Nov 2015
Newhaven
Gbrf and class 73s. They obviously serve their purpose with RHTT etc for a short part of the year, but by the end of the season just gone most of the workings (including W90) were covered by 69s anyway. There was even a few 66 workings.
With more 69s still rolling off the production line and new gbrf locos on their way, I can't see 73s been used much longer ....
I guess their main benefit is the 3rd rail.
Towers
30 Aug 2021
Indeed. They offer a very useful ‘green’ credential, I wouldn’t be at all surprised if that buys them a good few years more use doing circuits on the southern. This is particularly relevant when you consider locations which are actively ‘anti-diesel’, like certain London terminals etc; presumably that stance is only likely to expand as the years go by. I’d imagine a 73 also likely has much better route availability than a large heavy diesel?
Doomotron
25 Jun 2018
Kent
There are only 16 Class 69s. The majority of RHTTs (in Kent at least) are still hauled by 73s, and there have been no plans to replace them.
Yes, the 73s have very good route availability.
If you think SWT having 73s is weird, you'll probably find their Class 960 (121) even weirder.
py_megapixel
5 Nov 2018
Northern England
I remember being taken by surprise on the through platforms at Manchester Piccadilly when a Transpennine service to the airport was announced and a shiny new EMU whizzed into the station, apparently fresh out of the factory (it hadn't even had the vinyl livery put on yet), in place of the expected 185!
Class15
30 Dec 2021
North London or Mildmay line
Most of the 3W75/3W90 RHTT circuits last year were 69s which was a trend on all Tonbridge RHTTs from what I have seen.
Another example: I was amazed to find out that London Overground had Class 508s. Apparently they even had to be hauled into Willesden depot by a 313 due to no third rail!
Bringback309s
22 Aug 2013
The Hornsey shunter! http://ukrailways1970tilltoday.me.uk/NVR2008DdayMarch4.html
This class 03 was based at First Capital Connects Hornsey Depot in 2008 . It job was move the EMUs about the depot. This was only when there was no overhead electricity or the EMU pantograph was not working or damaged or some other fault that meant it could move under its own power.
The class 3 did just a a few miles around the yard at Horsey, is why it was so clean or had it been doon up for it visit to the NVR.
Sun Chariot
16 Mar 2009
Knights Rail Services (Eastleigh): 07007. I was astonished to see it, in BR Blue livery, when I flew into Southampton Airport 5 years ago.
Until I first saw them in spring 2023, I hadn't realised Network Rail was using class 153s for track inspection.
153385 and 'blue brick' 153376 have been fairly regular along the West Coastway and Portsmouth Direct lines.
Mag_seven
1 Sep 2014
here to eternity
They are of course used by GBRf on the Caledonian Sleeper.
Warrior2852
27 Oct 2018
Knights Rail Services (Eastleigh) - 07007. I was astonished to see it, when I flew into Southampton Airport 5 years ago.
I do find it amusing how Network Rail sometimes doesn't repaint stock they've acquired from elsewhere, like with the ex-EMT 153 here, leading to finding some heritage liveries that have disappeared from everywhere else still among their ranks.
CaramellDansen
6 Jan 2024
I wonder, given Merseyrail's desire for more unelectrified expansions, if 3rd-rail/diesel bi-mode loco(s) would be of interest to them! Not sure how else they'd rescue a failed battery loco!
(They could always put some bloody wires above the tracks!! <( )
BrettSy96
27 May 2019
Was watching a video of trains from around 20 years ago and saw a class 31 in West Coast livery which I never knew that had!
Prime586
26 May 2023
Knowsley
In the early 90s Merseyrail aquired 5 Class 73s (4 active and one parts source) that were used for departmental, engineering, and sandite duties (two that were renumbered into 73/9s). They were all withdrawn by 2002 and sold into preservation (the 73/9s were converted back to 73/0s and later sold on to GBRf to be converted into their 73/9 'Ultra' configuration).
Taunton
1 Aug 2013
Maybe not aware (purpose of this thread) that previously there was indeed a small fleet of Class 73 which were on Merseyside for quite some years after the Liverpool Loop opened, they replaced equally odd battery service stock rebuilt from Euston-Watford Class 501 trains, being there in the 1980s-90s, although I never saw them move from outside Birkenhead North depot.
xotGD
4 Feb 2017
Am I right in thinking that GBRF have a Class 47?
Rail Quest
8 Apr 2023
Warrington
It baffled me to learn Northern (whatever the franchise at the time) operated a small number of Adelantes (three I believe) for a short time on the Hazel Grove to Blackpool services, a service with many differences from their designed use cases.
hexagon789
2 Sep 2016
It baffled me to learn Northern (the franchise at the time) operated a small number of Adelantes (three I believe) for a short time on the Hazel Grove to Blackpool services, a service with many differences from their designed use cases.
Also did Manchester Vic/Blackpool
CaramellDansen
6 Jan 2024
You don't say! Thanks for the shout, and the pictures!
I wonder what they're using now
How bizarre! That's certainly news to me!
generalnerd
20 Jan 2025
Hull
Oh wow! I wonder why? (It didn’t reply and didn’t work so pretend the image attached is the original post)
D365
29 Jun 2012
Indeed. The Brush modified 73/9s are the only diesels currently available which are compatible with the coach control/communication systems.
hexagon789
2 Sep 2016
They were short of stock and they were available. Eventually some ex-London Midland 150s were transferred and the 180s withdrawn.
