Ipswich-Cambridge - not valid via Ely?
XmaX
4 Jun 2015
I am looking at off-peak return tickets between Cambridge and Saxmundham which normally require a change at Ipswich. However, for the return journeys it's actually 18 minutes quicker to go Saxmundham-Ipswich-Ely-Cambridge rather than Saxmundham-Ipswich-Ely (all travel is on GA). National Rail website says they can't price the journey if I go via Ely, and Greater Anglia website doesn't even list it. Is the route valid or not?
Mcr Warrior
8 Jan 2009
Assuming the OP is travelling on a same day return basis, could they instead purchase the slightly more expensive Saxmundham -> Ely off peak day return (CDR) ticket (70p more?), and then break journey at Cambridge, so as to allow same day return travel via Ely?
XmaX
4 Jun 2015
That's a good idea! I was thinking of using the Anglia Plus Ranger, but this is a cheaper option.
Is there any rationale for Cambridge-Ipswich not being valid via Ely, but Ely-Ipswich being valid via Cambridge? The distance is roughly the same, the only difference I can see is that Ipswich-Ely train runs once every 2h as opposed to every 1h for Ipswich-Cambridge.
alistairlees
29 Dec 2016
It’s not a mapped route in the routing guide. Probably for very historic reasons when there were almost no trains between Ely and Bury St Edmunds. It’s more than 3 miles longer than the shortest route by rail, and it’s not a direct train.
gingerheid
2 Apr 2006
It could be worth asking GA about this! After a relatively tiny amount of prompting a few years ago they made Cambridge North to Ipswich via Ely fares appear :)
freddie1729
24 Nov 2017
If Cambridge North to Ipswich is valid via Ely, could one rely on easement 700714 and buy the ticket to Cambridge North?
Tickets to/from Cambridge are also valid at Cambridge North and tickets to/from Cambridge North are also valid at Cambridge. This easement covers all tickets, including season tickets, except Advance tickets.
Haywain
3 Feb 2013
There are no such fares showing in BRFares, only tickets routed 'Any Permitted'.
JB_B
27 Dec 2013
Any permitted tickets from Cambridge North to Saxmundham (and Ipswich* ) and v.v. are indeed valid via Ely so that looks like it could be a solution.
* - thread title ( Ipswich-Cambridge ) doesn't quite match the journey the OP is presumably looking at (Saxmunham-Cambridge).
That's true - I assume that @gingerheid must be referring to other routeing guide changes that made the route via Ely possible.
