If I pay £30 for it, how many times a year will I need to travel from Clapham Junction - London to make it worthwhile? Each anytime return ticket is £5.90.
The Network Railcard has a £13 (£17 for Anytime day Travelcards) Minimum fare on weekdays, and is not valid at all before 10.00 a.m.
The discounted fare is £3.90, so you'll break even after 15 return journeys.If I pay £30 for it, how many times a year will I need to travel from Clapham Junction - London to make it worthwhile? Each anytime return ticket is £5.90.
The discounted fare is £3.90, so you'll break even after 15 journeys.
However, the Mon-Fri minimum fare of £13 will effectively restrict its use to weekends and public holidays only.
The off-peak single PAYG fare for a NR Z1-2 journey is £2.10 (£4.20 return), so more expensive than the discounted off-peak return.If you just want it for travel between Clapham Junction and London I reckon you'd be much better off just using an oyster card which I believe is much cheaper, even taking into account any discount offered by the Network Railcard on the ticket you propose to use.
Is your Travelcard issued on an Oystercard or on paper? If it's on an Oystercard, then you'd only pay £1.90 for each off-peak single journey in/out of Waterloo or Victoria, using Oyster PAYG.I already have a Zone2-6 travelcard, so just looking at ways to get into London.
There are no Network Railcard discounts on Oyster PAYG.
Definitely! (The OP hadn't posted about it only being 10-12 journeys when I wrote my post.)Given the OP is only intending to travel between the two stations 10 to 12 times a year (and 15 journeys are required to break even, 16 to start making any savings), would using an Oyster not be more beneficial anyway, that is (assuming 12 return trips to be made at weekends):
Your Travelcard is also valid for use on all TfL bus services - even in Z1.
It's really surprising how much paper tickets are. On my Oyster last Sunday I paid £4.60 to get from East Croydon - Totteridge & Whetstone!
You can do that at Vauxhall (your Travelcard is valid that far) which may be useful if making an onward journey by tube.It's a paper monthly. I actually come from East Croydon, so if I have time exit at Clapham and buzz myself back in with an Oyster.
Although with your Travelcard you only really needed to pay a Z1 tube fare. You might want to consider changing to get a Travelcard on an Oystercard (although it would mean losing any specific additional benefits you may be getting from your current TOC-issued Travelcard).It's really surprising how much paper tickets are. On my Oyster last Sunday I paid £4.60 to get from East Croydon - Totteridge & Whetstone!
What Oyster PAYG also does is restrict you to using trains that stop at Clapham Junction, which means that using Thameslink services into the core is not an option.
Not at all. If you have your Z2-6 Travelcard loaded onto an Oystercard (with some PAYG balance) and made a journey such as East Croydon to Totteridge & Whetstone, then when you touch out at Totteridge & Whetstone it will simply charge the appropriate Z1 PAYG fare - as it knows you would have had to travel via Z1 to make the journey.What Oyster PAYG also does is restrict you to using trains that stop at Clapham Junction, which means that using Thameslink services into the core is not an option.
It does create that restriction in the OP's current situation of holding a paper ticket. This is what I specifically referred to as bb21 clearly managed to understand.Not at all. If you have your Z2-6 Travelcard loaded onto an Oystercard (with some PAYG balance) and made a journey such as East Croydon to Totteridge & Whetstone, then when you touch out at Totteridge & Whetstone it will simply charge the appropriate Z1 PAYG fare - as it knows you would have had to travel via Z1 to make the journey.
(Of course, if you travelled via the WLL/NLL, interchanging between Kentish Town West and Kentish Town, the system would know that you hadn't travelled via Z1 and thus (technically) shouldn't change anything extra.)
Welcome to London. Paper expensive. Oyster and contactless cheap!
No only a monthly ticket.
