What do people reckon is the quickest way from King's Cross (let's assume you arrive into platforms 1-8 and alight from the front of the train) to Paddington (let's assume you want to depart from platform 1)?
Could it be via Farringdon onto Crossrail? This is perhaps counter-intuitive from the point of view that you are heading away from yourself, but it might actually be quicker, given the H&C/Circle option isn't a particularly fast route.
Assuming it is via Farringdon, I'd say it would be quickest to get to Farringdon via the sub surface LU lines rather than Thameslink, though the answer may be different if you were arriving into St Pancras from EMR.
What I've tended to do in the past is get the first available train heading west on the sub-surface lines; if it's not a direct train to Paddington, I would get off at Baker Street (from about the 3rd/4th car from the front) and nip down to the Bakerloo, to avoid waiting for the H&C at King's Cross.
If you wanted to get to a higher numbered platform, this is far less likely to be quicker on Crossrail, given the further distance to walk at Paddington from the Crossrail platforms, combined with a shorter walk from the H&C.
I guess the Crossrail option will also be more attractive once the frequency increases.
