Kings X to Moorgate - Northern or Metropolitan et al
westv
29 Mar 2013
My office has just moved. Previously I'd get the metro/circle to Aldgate and a 5 min walk from there. Now the closest station is Bank. Ideally I would have preferred to use the old route, get off at Moorgate and have a 10 min walk. Much prefer the lines closer to the surface and the air con stock.
However, I know that Kings X to Bank on the Northern line is quicker so I decided to give that a go this week. I gave up as there was a non moving crowd just to get through the KX barriers! Decided to use old route. This was around 9:15 this morning. Was this a one off or a regular occurence? I only use the route Friday afternoon and (normally) Monday morning.
On another note, is it just me or is Moorgate tube exit to Moorgate east side confusing? I've tried twice now and twice not ended up coming out where I wanted to!
SaveECRewards
22 Jan 2015
I'd stick with your preferred route. It's not fun in a tube train in rush hour. Even when I worked near Monument I had been known at times to just take the circle round if one was due in the next 10 mins rather than go down to the quicker Northern line.
StateOfPlay
27 Aug 2015
Private
A very busy route. I used the Finsbury Park to Moorgate service as a trial and found that more crowded than the tube. I work in Leadenhall 1 week every 2 months and use the Northern Line for speed, my wife visits her head office once a week and avoids Bank station, using the circle line to Monument instead. I am thinking of doing the same when I am there next month.
I use the Victoria line to Victoria at the moment, great service but the trains are not as nice as the circle line, and could really do with some air conditioning.
bluegoblin7
10 May 2011
EF
KX is getting increasingly worse during the mornings. There's just more and more people starting to use the station resulting in congestion. If there's any line problems then this will make the situation worse still.
I wish I could say it was a one-off!
I'd definitely stick with your existing route during the morning, although KX will be the better option on the way home.
jon0844
1 Feb 2009
FPK to Moorgate should be okay if you board at the rear of a six car train. A lot of people get off to change to the tube, but I wouldn't like to try and board one of those trains between Potters Bar or New Barnet and FPK!
The new stock should help a lot but only because almost everyone will be standing in the first place!
Coming back, it's a case of getting down the right platform quick to board what will start as an empty train. When I worked at Old Street I occasionally boarded a southbound train and stayed on, but needed to know it was going to be the right destination!
westv
29 Mar 2013
Ok thanks for the replies.
I think I'll stick with my current route then although it's a slight pain as I like to get on at Kings X at the rear of the met/circle line train. At Aldgate that was fine as the exit stairs weren't too far away but at Moorgate the exit is right at the other end of the train.
A0
19 Jan 2008
Where are you coming into Kings Cross from ? If it's north on the GN, why not get off at Finsbury Park and take the GN service to Moorgate?
Finsbury Pk - Moorgate is same time as Finsbury Pk - Kings Cross. Even allowing a few minutes to change at FPK it's probably quicker.
For the City I increasingly use Met to Moorgate and walk rather than the Northern Line, which is a very unpleasant experience (particularly as the subsurface lines have the rather nice S-stock).
D365
29 Jun 2012
Peterborough non-stop trains (stopping north of Hitchin only) don't call at Finsbury Park so it's not always workable.
TheNewNo2
31 Mar 2015
Canary Wharf
I'd say go via the SSL - the trains are bigger, air conditioned, and also the line between Bank and King's Cross just feels like it takes an age without really getting anywhere.
westv
29 Mar 2013
Hull Trains so a change at Finsbury Park isn't an option.
Tetchytyke
12 Sep 2013
Isle of Man
Northern Line trains are always hugely overcrowded between 8am and 9am- when I was commuting from Muswell Hill it was a squeeze for me to get on a Bank Branch train at Archway- and if you can avoid it you should avoid it.
Busaholic
7 Jun 2014
And just think of the fun when/if all those extra people get on at Camden Town from the Edgware branch if the split happens.
D365
29 Jun 2012
Which will be compensated for by the ability to run at least 10 more trains per hour.
Busaholic
7 Jun 2014
The actual, rather than theoretical, ability to run 10 extra trains each and every hour will depend, at least in part, on how long the 'dwell' at Camden is. The proof of the pudding... Ditto Thameslink core, for different reasons.
D365
29 Jun 2012
The Northern line split is entirely motivated by the desire to run more trains on each 'branch'.
westv
29 Mar 2013
12 minutes fast walking from my desk in Lombard St office to Moorgate west direction platform.
robbeech
11 Nov 2015
Sorry for the thread hijack, can someone link me to information about this Northern line split. I seem to be spending a third of my time in Camden at the moment travelling in and out of St P or King's X.
Where i stay there is actually closer to Mornington Crescent which is a little tedious having to change at Euston or walk up to Camden Town (in fairness its 10 minutes so i'm hardly complaining).
westv
29 Mar 2013
As it was raining on Monday morning I tried out the Northern line to Bank.
As mentioned earlier, the journey does seem to go on and on, the trains are very busy ( this was around 9:20) and Bank station is a maze. I ended up exiting via the Central line platforms although I expect I made a mistake in my navigation!
TheNewNo2
31 Mar 2015
Canary Wharf
From the Northern Line platforms, follow the exit signage. This should take you in to the main set of escalators from DLR to Central Line. You want to go up one level, then turn right.
westv
29 Mar 2013
I thought I was following the exit signage but I must have made a mistake.
Bookd
27 Aug 2015
Bank must be a contender for the old joke about Willesden Junction; that it was haunted by the ghosts of people who had died of old age while trying to find the way out!
