I was just pondering whilst stood waiting for a level crossing to raise the other night about how level crossings and specifically Manually Controlled Barrier (MCB) crossings (whether they controlled directly by a signaller in the adjacent box or via CCTV or Obstacle Detection) work in terms of interlocking with the signals. My understanding is that for the protecting signal to clear the MCB has to be down and if the signalling system cannot detect the crossing as being down the signals will not clear. Assuming I'm right, so far so good.
My question is more about what happens once the barriers are down and the signal clears. Does that then lock the barrier controls so that they cannot be raised as long as the route is set over the crossing? When a train is in section are barriers locked until the train is clear of the section and the overlap and the route releases? I was just wondering as last night I could see the signaller stood by the controls for the crossing but it took a while for them to actual raise the barriers even after the train had passed which led to me wonder if that was because they had to wait until the train was clear of the overlap and the route had been released?
