List of stations with one track but platforms either side
Pompey00
Repeatedly returning banned member
15 Aug 2022
Portsmouth
can people help me list stations what’s got a track but platforms both sides whether they are both in use or only the 1 for example.
Guildford has a platform both sides but only 1 side is able to be used due to the 3rd rail.
61653 HTAFC
18 Dec 2012
Yeovil Pen Mill (platform 1 & 2 serve the same track, 2 no longer used)
Platform 2a(?) at Sheffield Midland
Magdalia
1 Jan 2022
The Fens
I can't believe this has not been done before.
Finsbury Park has two, platforms 2/3 and 6/7, with doors opening on the platform 2 and 7 sides.
Pompey00
15 Aug 2022
Portsmouth
signed
13 May 2024
Paris, France
Outside of the UK, Paris Gare de Lyon has Hall 1 with all except 2 mainline platforms (A to E) in that configuration
CEN60
17 Dec 2018
Greenford Road Single Line - Platform Either Side (Flanked by LUL I think)
A 2019 version ran to 3 pages:
In the 2019 thread I linked, I think it was noted that although some double faced platforms do have two signed numbers, such as at Guildford, one is not normally used nowadays.
Others such as the now removed inset bays on the main island at Reading, the old P6 and P7, only had a number signed on one side. But people reckoned with slam door stock passengers used both sides anyway.
Southampton P5 was at one time a passenger platform, with a short parcels platform on the outside at the buffers. Would that count as an example?
Derby had a two sided bay with only one side signed before the last remodelling.
Gloster
4 Sep 2020
Up the creek
I was in Guildford last week and there were large ‘Do not alight this side’ or ‘…here’ on the old platform 7.
Shimbleshanks
2 Jan 2012
Purley
Changing the subject slightly, is it possible for trains to have the doors on both sides open simultaneously or is there a feature that prevents that happening? If you could have both sets open at the same time, alert passengers could use the train to cross between platforms instead of the footbridge or subway.
Bristol
I believe some stock can open doors both sides (and is done at e.g. Stratford) but some have an interlock, although happy to be corrected on that. Due to additional despatch required if both sides are open I would guess it's preferred to only open one side unless there are interchange or accessibility reasons to open both.
snowball
4 Mar 2013
Others will know better but I've definitely seen a photo of an LU train with doors open onto platforms both sides.
And while on the subject of non-mainline, Metrolink has a line with platforms both sides at Manchester Victoria, but I think they are not opened simultaneously.
Pompey00
15 Aug 2022
Portsmouth
As Guildford accidently opens wrong side sometimes which is the 3rd rail side and it’s dangerous and the guard can get in trouble
Alex_L33
1 Oct 2013
They are, as far as I recall. The central platform is usually used to turn around trams to/from from the Airport. I think the doors were released on both sides simultaneously last time I travelled that way.
5 Jan 2014
There's also Ascot with platforms on both sides, although a fence has now been built along the platform 2 side.
Yes and before they built the fence doors were activated on both sides at Ascot
MarkyT
20 May 2012
Torbay
I don't think it 'just' the 3rd rail. That trains don't officially call on the wrong side doesn't prevent passengers on the platform waiting for trains from other faces falling from it onto the live rail when there's no train there. Closing doors on both sides after a station dwell can take longer and may be be more risky. In unlocked slam door days there was little staff could do about people getting off on the 'wrong' side. I don't think anywhere on the mainline in UK has this design explicitly for capacity management, but elsewhere and on metros particularly two faces are employed at extremely busy stops where there's a lot of passenger turnover, often using one face for arrivals and the other for departures with phased door operation so the exit side doors open prior to the entry side. It is sometimes referred to as the 'Spanish solution'.
