norbitonflyer
I am looking at how this worked.
The original numbering was based on the pre-grouping railways, with post-1923 builds filling the gaps
NER 1-2542
GNR 3001-4770
GCR 5001-6494
GNoSR 6800-6915
GER 7001-8900
NBR 9001-10481
The original pre-grouping companies did not, in general, group similar locomotives together, but simply allocated the lowest number currently available at the time the lovcomotive was built.
The post-1946 numbers were based on type
1-999 (and 10000) large six-coupled passenger tender (mainly 4-6-2)
1000-1999 medium six-coupled tender (mainly 4-6-0)
2000-2999 four-coupled tender
3000-3999 eight-coupled tender
4000-5999 six-coupled freight tender (0-6-0)
6000-6999 electric
7000-7999 passenger tank
8000-8999 shunting (including petrol engines - later also used for diesel)
9000-9999 freight and mixed traffic tank
Within each group each class had its own number block, allocated generally in order of physical size
Note that one locomotive based at, say, Aberdeen could be waiting for a number to be released by a locomotive based in Stratford - or outshedded at some remote branch terminus. How was this co-ordinated? In other cases a locomotive might take on a number previously allocated to another member of the same class, which could lead to misunderstandings.
As in many (probably the majority) of cases a locomotive's new number in the new scheme had been allocated to a different locomotive in the old scheme, it was deemed necessary to organise the renumbering in stages - first renumbering those locomotives whose new numbers were vacant in the old scheme, and then those whose new numbers had been relaeaed in the previous stage and so on. An added complication was that, because inadequate space had initially been made for some new classes, some locomotives were renumbered twice - most famously "Flying Scotsman" (from 4472, first to 502, and then to 103 when the 5xx block was needed for the new A2 class)
Some of the chains could be quite long - more than a dozen steps - so how was it actually organised?
Was an edict sent out (every week? month?) to each depot with instructions on which locomotives should be renumbered? How long did this all take?
Were there any circular chains, and if so how were they handled?
Update - the longest chain I have found so far involved 23 renumberings
7211 - number vacant: previously a GER class F4
GER class F5 7110 to 7211
GCR class F2 5782 to 7110
NER class J27 836 to 5782
LNER class V2 4807 to 836
LNER class J39 2781 to 4807
GER class E4 7463 to 2781
NBR class C15 9164 to 7463
NBR class N15 9223 to 9164
NBR class N15 9225 to 9223
GCR class N4 5513 to 9225
GER class J16 8163 to 5513
NER class D23 No 23 to 8163
LNER class A4 4482 to No 23
NBR class J35 9195 to 4482
NBR class N15 9240 to 9195
GCR class N4 5636 to 9240
NER class J24 1948 to 5636
LNER class K2 2447 to 1948
NBR class D32 9886 to 2447
NER class H1 1527 to 9886
GER class B12 8527 to 1527
GER class J69 7350 to 8527
GNR class C12 4009A to 7350
No 4009A had been added to the GNR duplicate list in 1921 (as 1009A) to make way for a new K3 locomotive. It was one of two on the GNR duplicate list to make it through to renumbering - the other was J53 No 155A (LNER 3155A), trasferred to the duplicate list in 1906 to make way for one of the relatively short-lived L1 (LNER class R1) 0-8-2Ts (all withdrawn by 1934)
EDIT - longest chain corrected
NER 1-2542
GNR 3001-4770
GCR 5001-6494
GNoSR 6800-6915
GER 7001-8900
NBR 9001-10481
6000-6999 electric
