LNER Smart Save
moleman212
21 Aug 2011
Has the LNER app done away with split ticketing (Smart Save) - Doesn't show at all for an LNER journey on advances that I want to take that are cheaper as splits.
Adam Williams
2 Jan 2018
Warks
It does appear so, I can't get it to surface (even keeping in mind the usual limitations - e.g. ensuring no Railcard is applied).
Perhaps illustrates the danger of relying on the train operator to split for you.
Worth noting that (I think) it only ever split Advances - most of the good value splits on the fare increase trial routes involve part of the route being a non-London day single/return so they don't come up even where it is working. It's notable that Trainline do show these so I bet (given Trainline's market share) they're having a big impact on the trial itself - can't say I'm upset by that :D
In a way no other TIS supplier would get away with doing, yeah :D
The way it works/worked (I did buy one once) was to apply a percentage discount to the through Advance fare to bring it in line with the cost of the two split Advances added together. (I'm sure you know that but others may find it of interest).
Adam Williams
2 Jan 2018
Warks
You're quite right, and obviously if you're going to get the revenue from ORCATS anyway because you're both the fare setter and retailer, then doing that doesn't make the slightest bit of difference to your overall position. Note that they never did it on &Connections tickets/non-LNER services or in cases where another operator was involved.
Haywain
3 Feb 2013
There was a suggestion at one time that it would be applied to flexible tickets as well but that idea was, fortunately, quashed!
It would probably be easier to write a script to go through all the walk-up fares and highlight those which had this sort of anomaly so it could be fixed than have the complexity of making the retailer do it. It's of note that nobody bothered writing such a script to check the south WCML Anytimes before they went live, though - there are quite a lot of split savings - it's surprising that a totally new clean-sheet fare set on a simple straight-line route with only one possible route for each journey was allowed to have such anomalies from day one.
With Advances it's more understandable as it happens quite a lot when a given quota level is available for only part of the journey.
Haywain
3 Feb 2013
If it was that easy there wouldn't be anomalies.
Sealink
16 Aug 2006
I never found the LNER Smart Save that good... discounts where generally in the single pounds (whereas a Split Ticketing website saved me almost £150 for the same journey.
Kite159
27 Jan 2014
West of Andover
Or in the case of LNER if you were looking for advance tickets for London to Newcastle ->Edinburgh at times where the super offpeak single would be valid if it still existed some savings when the system would generate something like London to Darlington & Darlington to Edinburgh which still benefit from the price cap.
redreni
24 Sep 2010
Slade Green
Not of any concern to the end-customer, of course.
No, I suppose not. Not if it's only splitting Advances.
I guess in the case of disruption, say the scheduled train is cancelled and the next one doesn't call at the split point, it could be better to have the through ticket rather than split tickets. Appreciate that's stretching a point, though.
Joe Paxton
12 Jan 2017
I've missed this development - so Avanti have set new Anytime fares on the WCML?
