LU Drivers - Best lines/depots to work for/at?
Mattyblob
29 Apr 2017
Hi everybody, long time lurker but first time poster!
I'm one of the many currently going through the application process for Night Tube (long term interest in train driving, have previously passed all OPC assessments but failed the DMI for my local TOC) and I've got some questions for any current/ex LU drivers that would be willing to advise as I can't find any info of this nature online.
As the title says, are there lines/stock that are better to work than others? Are there any significant differences between depots? Are certain lines better in terms of temperature in the cab whilst driving (sub-surface, air con, cooling facilities on certain stock)?
I understand that the Pic is the only night tube line that doesn't currently use ATO, is it worth going for this and enjoying the experience as much as possible before ATO becomes standard across the network? (2022 on the Pic IIRC).
Of course I've not yet had any outcome regarding my application but I'm certainly hoping I'll get to make use of this information, and if not I'm sure others may find it of interest!
Thank you in advance for any responses :)
Lrd
26 Jul 2010
You don't get a choice at first. You will be allocated a depot based on the needs of the company. You will then be able to nominate a depot but will have to wait for a vacancy (and do a minimum one year of Night Tube) before being called.
Each line is very different and has pros and cons which will be different for each driver. Different people like different things. Worry about getting in first and then do your research about each line, which you will get from other drivers and staff you meet etc.
Mojo
7 Aug 2005
Won't be any time near that; the trains won't even arrive by then, so signalling upgrades will take years after.
As a Night Tube T/Op your shifts will be pretty much the same wherever you go. If you want to apply to go full time then it depends what you want in terms of duty start/finish times asto what depot is better.
Bromley boy
18 Jun 2015
From a recent thread on here, it seems that drivers can drive manually on ATO lines, certainly the Northern and Central, if they so wish.
donpoku
26 May 2015
That cannot be the case due to time consistency and safety implications of the signaling system.
Sent from my LG-H850 using Tapatalk
Met Driver
8 Jun 2005
You're mistaken in that belief. Manual driving (which is supported by cab signalling and ATP) is mandatory on Sundays and bank holidays on specified sections of the ATC lines (Victoria excepted), and permissible under certain circumstances at all other times of the week/all parts of the lines concerned.
Mattyblob
29 Apr 2017
Thanks for your replies. Is there opportunity to drive manually on Jubilee too at certain times/situations then? Thought the platform edge doors would prohibit it!
Mojo
7 Aug 2005
The Jubilee line extension (along with the rest of the line) was manually driven from its opening in 1999 for around a decade until the new signalling system was fully functional over a decade later.
bILLOO
6 Jul 2011
Which parts of each ATO line are favoured for Sunday manual driving?
slidingdoors
15 Apr 2017
Central Line is East of Leytonstone and West of White City
Does that apply on the night tube too? Presumably it's done so operators can 'keep their eye in' so to speak? When do the night tubers get this chance?
up1989
23 Oct 2016
on night tube, northern you can drive in manual when ever you like, you get a call from the signaller if your running late to switch back to ato.
After some practise you can drive better than the ato as you learn the road and the speed restrictions. Ato is rather jerky on the Seltrac system as it doesn't use all of the motoring arc.
Lrd
26 Jul 2010
Yeah it is, it's done after 2am on Sat night/Sunday morning
Yes you basically can drive manually whenever you like. The system provides full safety protection, but the flip side of the coin is you have to be able to drive to ATO levels of performance - both in terms of maintaining time and not having errors. Some individuals are better at this than others, but providing one is not flagging up in either of these areas then they will generally be left alone to do their own thing. The one exception is the Victoria Line, which is partly historical as the line has been ATO from day one, and partly due to the sheer intensity of the service.
The rest:
Jubilee, Wembley Park - Stanmore.
Northern, West Finchley - High Barnet & Hendon Central - Edgware.
The Northern has changed, I can't remember exactly what it is, but due to some issues with trains stopping in fractionally the wrong place, it was changed so that it no longer included Edgware. It's something like Hendon Central to Hampstead now - on the rare occasions ANP is actually implemented nowadays.
Met Driver
8 Jun 2005
They'd better update the line supplement then. :)
Met Driver
8 Jun 2005
It's also not possible to replicate ATO performance as a much gentler braking curve is enforced by the ATP when driving in PM, so it's impossible to hit platforms in the same manner as ATO, for example. This is not the case on the other ATC lines.
GW43125
8 Dec 2014
Doesn't PM also restrict max speed?
Hmm. Up until the recent software change this was undoubtedly the case. Now I'm not so sure... I'd like to know a bit more about exactly what changes have been made to the software, but so far the line seems a lot slower.
Not on the Central, Jubilee or Northern Lines - the system allows the driver access to exactly the same speed profile as the ATO uses.
(In fact, on the Central Line it's technically possible to achieve 100 kph in Coded Manual whereas the ATO will not exceed 85 kph, although exceeding 85 kph in CM is prohibited by a rule instruction. This anomaly has been present ever since the 85 kph restriction was brought in after Chancery Lane).
Met Driver
8 Jun 2005
Nor on the Victoria line, except under certain train-borne fault conditions, in which case ATP enforces a lower maximum speed (known as limited protected manual).
How does it work in PM on the Vic approaching a platform or red signal? I'm presuming that, like TBTC, the maximum allowable speed drops in the form of a braking curve. One lovely feature of the Central Line is there generally isn't a braking curve as such - only the maximum speed dropping in steps at some locations - thus generally allowing the driver to enter a platform at whatever speed they desire within reason. The Northern is okay where tunnel braking rate applies as this is generally in line with hitting a platform at 35-40 mph, however in the open sections it's rather painful being forced to enter a platform at half the speed compared to when driving under signals!
Met Driver
8 Jun 2005
Basically no different to TBTC except the PDP (Vic speak for TOD) displays things slightly differently (ironically, pretty much identical to 4LM CBTC). However, unlike TBTC, for a signal stop between stations there is always a wayside reference point to aim for, be it a block marker or colour light signal, in addition to the information on the PDP. In some ways, it's a combination of the Central line system and TBTC.
There are a fair few stations on the Central where, subject to the starter being clear, ATP doesn't demand a speed reduction through the platform.
Yes I've never understood why the Victoria Line has a timing section on the station starting signals when the speed is already supervised by the system.
So on the Vic are you saying the hand comes down very early when approaching a platform in PM compared to ATO? At least with TBTC it is the same, for all it's other faults. The Vic seems to have been ruined since the new software went in- painfully slow now.
DJ737
15 Nov 2009
Melbourne, Australia
Back in the day I used to drive in coded manual on sunday mornings with the 67 stock and using the Westinghouse at all stations from Walthamstow to Brixton and back.
Cheers
DJ737
Bromley boy
18 Jun 2015
To the LU drivers who've switched from ATO to manual lines, or vice versa, which do you prefer?
Does the ATO driving become monotonous, or do you prefer it?
This is hopefully still relevant to the OP's original question.
Mattyblob
29 Apr 2017
Yeah I'd like to know people's thoughts in this too if I'm honest!
Thank you for your replies so far everyone, very informative :)
Webby
6 Sep 2016
Does any body know if there is parking available for drivers at any of the depots?
