From memory the sand train runs via Doncaster and KY to MB.
Normally runs round at MB at 16:15 hrs ish.
The loco goes light engine upto the gates of the glass works to check the road is not obstructed and the gates are open.
The the loco runs light engine back to the RR, and attaches to the rear of the train.
The shunter stays up at the glass works, and uses back to back to radios to control the propelling movement.
The driver pushes the full train up the incline.
On reaching the glassworks, the train shunts off 14 trucks into the sidings as the discharge road can only accomodate 14 trucks.
The train is split and propels onto the discharge road right upto the buffer stops and then proceeds to empty the trucks 1 at a time.
To get the 14 trucks over the discharge hopper, the buffers on the train have to be compressed on the stop blocks.
When the first 14 trucks are unloaded the train sets back down the incline and onto the other half of the train, draws them out and places them on the discharge road as before.
This is assuming that the train has 28 trucks on.
The train is controled by token signals under the control of the operator.
When the discharging is complete the shunter inspects the train for open doors etc and gives the driver a drivers slip with the new loadings on it.
Every time the train is split. a brake test is carried out.
The train then departs around 1800hrs back to Donny.
This railway is a high tresspass area and care must be taken when on this branch.
When the train is split, 5 trucks have the brakes pinned down and 3 scotches are placed under the first 3 trucks.
