Hullo all,
Having recently found out that since for my situation it actually works out cheaper to buy singles than season tickets (due to my Disabled railcard), I've been buying them. So I was idly playing with brfares.com & found an even cheaper fare that I wasn't sure would be allowable so I thought I'd check before I buy!
I have the following:-
DIS - Disabled Railcard
FDM - Freedom Pass
In the past, I bought the following...
1 single SAC-WHP (St Albans - West Hamstead TL)
1 single ELS-SAC (Elstree & Borehamwood - St Albans)
Works out to £9.70
This is because of FCC's restriction that a freedom pass can't be used on the ELS-WHP leg in the AM. Also, for some reason, ticket offices tend to take _forever_ to grasp this concept & to issue tickets
However, brfares.com website threw up the below (which hopefully should be easier)
1 return SAC-ELS
1 single ELS-WHP
Works out to £8.80 - wahey!
So effectively on a single journey from SAC to ZFD, I'd be using three tickets(!). But hopefully also easier for ticket offices to go "Ah, I see. Ok. *tap tap*"
Is this a problem? Is there a better way to purchase in bulk perhaps?
FDM - Freedom Pass
Works out to £9.70
1 return SAC-ELS
1 single ELS-WHP
