Tin Rocket
Hi,what are the purpose of neutral section arcing horns/catchers? and what is the detrimental effect on the horns when they become burnt?
cheers
cheers
Sacrificial arcing horns are often provided in the event that a train draws power through the dead section.
Taken from GazK's book pg89
The detrimental effect is that they are wearing out, but the good news is that they are doing their job.
The term Neutral Section is a bit of a misnomer in that it is of course earthed. If a train fails to clear its circuit breaker via the APC magnet and is still drawing current as it enters the NS then it will draw an arc.
Sent from my iPhone using Tapatalk
Potentially major short circuit to earth and the contact wire parting
that's right, a full neutral section has a sequence of electrically functioning parts as follows:
1) previous powered conductorIf the there was repeated arcing from pantographs still carrying load currents, there would be tracking across the insulators at the leading insulator. To prevent that, the 'horns' run parallel to the insulator meaning that the power is transferred to an isolated section of conductor after the insulator has been passed. Any high voltage transients are then dissipated as the pantograph parts company from the horns, (no stress occurs when an isolated conductor is added to the powered circuit). The insulators are rated to handle the maximum voltage spikes caused by the collapse of the current. If there is repeated breaker malfunctioning, the horns will eventually burn a bit but that is well withing the maintenance cycle of the OLE.
2) in-line insulator (usually made from alternate ceramic and PTFE beads)
3) isolated section of conductor
4) another in-line insulator
5) grounded neutral section of conductor
6) another in-line insulator
7) another isolated section of conductor
8) another in-line insulator
9) following powered conductor
ok thanks,will the pan be in contact with N/S insulators as it passes through the N/S?and also is there still electrical power in the carriages such as lighting or power points for laptops etc as it passes through a N/S?
