mike57
TPE have gone from 4 to 5 trains per hour between Leeds and Manchester, and there is no doubt in my mind the service is less reliable. When they increase it to 6 trains per hour it will no doubt get worse still.
Running more trains per hour must require more units, instead of making the timetable more fragile why havn't they just lengthened trains, and kept to the 4 per hour pattern. After all if you are turn up and go customer on the core Leeds Manchester route the the difference between 4 and 6 trains per hour is only another 5 mins max to wait.
Also why not some simple improvements to allow TPE trains to overtake stoppers, restore the Westbound through line at Dewsbury, Crossgates could have through lines, looks as if there used to be 4 tracks here, also Slaithwaite, and between Deighton and Mirfield. If these improvements were kept simple would they be prohibitivley expensive.
OK so they are small incremental improvements, but they would help to stop knock on effect from late running trains and allow a more robust timetable.
