Oyster – night bus / hopper fare
bakerstreet
29 Nov 2009
Just wondered if anybody on here knows whether in the following circumstances the 04:30 transport day change for fares purposes is relevant.
This is for TfL travel only, within London, Oyster not contactless, bus only.
Board night bus at 0400
Board second night bus at 0450
The 0430 day change for fares purposes will or won’t affect the hopper fare?
(For those who don’t know, the hopper fare simply means you can usually board any number of London buses within an hour of the first touch and be charged one fare only)
cockneyviking
22 Jun 2015
I regularly get a bus at 04:00 from A to B then a 04:45 bus from B to C and it's always been the hopper fare £1.75
AlbertBeale
16 Jun 2019
It seems to work as though the principle is that once you've tapped on a bus or tram, all further taps with the next hour are ignored, come what may. However, that isn't a blanket rule, since if you use the last credit on your Oyster and then change buses within the hour, the second bus rejects your card, even though no money is due. So the subtleties of the system aren't obvious...
zero
3 Apr 2011
Oysters with a negative balance are rejected
For daily/Mon-Sun cap purposes a fare deducted at 0400 (i.e. between 0329-0429) would count towards the previous day (= the current charging day)'s cap regardless of taps on further buses
