http://www.brtimes.com/#!board?stn=PAD&show=info&date=20160825
Paddington - Marylebone has a fixed link walking transfer time of 17 minutes (for the purposes of planning a valid travel itinerary, this must be added to the minimum connection time for each, which is 15 minutes and 10 minutes respectively, ie. totalling 42 minutes) which is very walkable, indeed less so than some out-of-London interchanges.
The main purpose of this appears to be to allow passengers to make interchanges at times when London Underground isn't running.
The electronic data is set to only show this walking travel in journey planners "from 0001 until 0529", as at other times any itineraries generated would show a tube transfer.
So, the question is: if you are travelling outside those times and can't, or do not want to, take the tube for the transfer (e.g. let's say you are taking a bike with you), can you choose to take the walking transfer at any time you please, and if so would allowing the minimum connection time above count as a valid itinerary for the purposes of Delay Repay, and making any last connections?
(The same principle applies for many other cross-London transfers)
