First class
- Joined
- 9 Aug 2008
- Messages
- 2,731
Hi all,
Just a quick question that one of our guards asked me earlier:
On the Merseyrail underground network, there is a grade called 'Station Assistant'. Their duties range from checking tickets to cleaning unthinkable deposits of the platforms.
Now, these staff are NOT Personal Track Safety trained.
The guard I was speaking to was concerned because two of these staff were using a machine called a Taski at Moorfields station, during operational hours, on the platforms. He also says that staff regularly use another machine, (which I belive to be called a 'Tandem').
See this link for picture: http://www.johnsondiversey.com/NR/rdonlyres/D6712CD9-25CE-48D2-90D9-B62888C15047/0/swingo1250Epc.jpg
My question is, for these staff to be operating machinery on the platforms, should they be compotent in PTS?
The rulebook says:
"Definition of On or near the line"
If you are on a station platform, you are not on or near the line unless you are within 1.25m of the platform edge (they are literally on the platform edge sometimes) AND you are carrying out engineering or technical work on the platform within that distance.
Then basically says to go on or near the line you need a Hi-Viz and PTS unless under supervison of a COSS, (which these staff arent).
So 'technical or engineering' - anybody want to comment on whether these staff are required to be trained in Personal Track Safety?
(On a side note Merseyrail only train Guards, Shunters, Drivers, some fitters and Operations Inspectors in PTS).
The rulebook says:
