Plymouth, or Penzance to Paddington service, driver allocations
Julius
8 Oct 2017
I was wondering how many drivers GWR would allocate between say Penzance and Paddington? Like a Penzance driver would drive to where, and then the next driver would drive to where? How many different drivers would there be, and where would they drive to? Obviously you can't be exact, as scheduling differs, but roughly who drives where?
co-tr-paul
8 Mar 2016
Helston, Cornwall
Regarding High Speed Services, PZ trained up to EX. LA trained to both PZ and Pad as are EX but don't know rosters. EX were trained to Bristol too but don't know if this is still the case. Sleeper is EX drivers except ecs to/from depots.
tgrb
11 Feb 2017
Guessing some EX must sign to Bristol for the couple of trains that go to via Bristol everyday?
irish_rail
30 Oct 2013
Plymouth
Both Plymouth and Exeter sign London via bristol as well as the b and h route.
Penzance only go as far as Exeter.
Generally services starting at Plymouth bound for Paddington will often be worked throughout by a Plymouth man whilet services starting at Penzance will often be worked by a PZ man to Exeter where an Exeter man will take over but this is not exclusively the case.
Paddington drivers also sign Exeter to Paddington but not as far as Plymouth.
Sleepers are driven on the down by an Exeter man to Exeter then a Plymouth man takes over to Plymouth then another Plymouth man takes over from Plymouth down to penzance. On the up its all Exeter men.
tiptoptaff
15 Feb 2013
EX sign PZ-pad via all possible ways, to be able to run the sleeper on the Up.
PHILIPE
14 Nov 2011
Caerphilly
And Westbury to Chippenham via Melksham. Being used all day this week due Electrification work at Newbury closing the B & H
Chris M
4 Feb 2012
London E14
Is "LA" Laria (i.e. Plymouth) in this context?
Right Away
18 May 2016
Bristol HSS drivers also sign the road from Paddington to Exeter by all ways with the exception of Castle Cary to Exeter via Yeovil.
Wilts Wanderer
21 Nov 2016
Isn’t there some problem with Plymouth crews not knowing the Hullavington road? So if a Plymouth-Padd service is diverting via Bristol it must be routed via Box if there’s a chance it might be worked by a Plymouth man, despite the Hully route being quicker and easier to path through Temple Meads (although Filton bank can be tricky.)
irish_rail
30 Oct 2013
Plymouth
Yes this is correct I still remember bristol panel trying to send me round hullavington one day when I got diverted , luckily I stopped. Have heard stories of PL train mangers being taken round Hullavington by Exeter drivers despite the TM not signing the road!
